![]() | Home > Technical (L322) > Engine Rattle on Start-up |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
I noticed, last winter,when the car had not been used for a few days that there was a "rattle" for just a couple of seconds on starting. I put it down to maybe the timing chain adjuster sticking and then freeing off. No hint of it when being used often and in the summer months.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8805 ![]() ![]() ![]() |
Does it have hydraulic tappets??, probably does..... if it does, it's because the oil will drain from them if left standing for a while and it will take a some time for the pressure to build up after you start it, I wouldn't rev it up if I were you, just drive it normally until it goes away... Pete
Definitely sounded like a loose nut/bolt/screw. I was not daft enough to rev it high from cold. I did have a belt changed last year (summer) not long after I had purchased the vehicle.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
I was going to say tappets too, especially as it goes when the revs are raised, that would be the oil pressure going up and re-filling the tappets. Might be an idea to have a listen under the bonnet on start up to try source the general location of annoyance before you rip the engine apart !! Yesterday I couldn't spell Engineer... Today I are one!
Rattle was originally on start-up. Last time it happened though, engine was warmed up and I dabbed the throttle to take it above 3000 rpm. The rattle returned with more urgency but then disappeared for good, when I took the engine above 5000. I won't know for sure until mid- November, when the car will have sat doing nothing for a fortnight, whilst I am at work! Previous cars:
