Home > Technical (L322) > Solution to damp in ECU's - cheap and simple, for a change! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34930 |
you could also run the ac as that will dry out the air.. ... - .- -.
15th Oct 2014 2:09pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
You should run the A/C once a week to stop the seals drying out and cracking, if you don't use it you'll loose it, refrigerant gas, wot did you think I meant Yesterday I couldn't spell Engineer... Today I are one!
15th Oct 2014 10:41pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
I thought the official advice was to keep the a/c running all the time to keep the vehicle dry. 2012 5.0L S/C
16th Oct 2014 7:20am |
its not 'official' advice but it helps if you have a water ingress problem and as said its best to have it running every so often to lubricate the seals.. ... - .- -.
16th Oct 2014 7:39am |
Certainly helps in winter to reduce condensation and clear the windows 2012 5.0L S/C
16th Oct 2014 7:41am |
