![]() | Home > Technical (L322) > Van Aaken Smart Box |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
not a FF but it should give you an idea,
and this on this forum,
gibbsy Member Since: 07 Oct 2014 Location: Stockport Posts: 11 ![]() ![]() ![]() |
Hi
Did you try calling the number on the device |
Hi
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
Hope they didn't go bust because of all the people suing them because their engines blew up!!!! Pete
Hi
To be honest I've never heard of them, I'd do lots of googling though.... just to be sure.... had a few chipped diesels over the years and never had any bother from cheap boxes off the bay to proper remaps so I recon you'll be alright... does look a bit complicated though.... Pete
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
They jump across the engine ECU plug... Unplug the ECU and you will find the wiring is the same so, the ECU plugs into one side and the other side plugs back into the ECU |
What about the two leads at the top the black and brown one? The brown one has a metal loop terminal making me think it a power feed from the battery or an earth.
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 ![]() ![]() ![]() |
The two extra leads look to be optional
Hi
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Van Aaken were based in the village where I live and operated out of units on the TRRL site that's now earmarked for more |
Finally got it fitted and all seems fine.
