![]() | Home > Technical (L322) > Adaptive Dynamics Fault light |
| rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 |
Top tip thread. Same issue here on my 2010 FFRR 5.0. 20 minutes later after a bit of cack handed soldering job-jobbed.
| XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995
| Q86ARR Member Since: 28 Jul 2014 Location: Cambridge Posts: 63
Land Rover technical bulletin LTB00416v3 covers this fault.
| Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223
Just had the same on mine, fixed in 30 mins with some soldering and re-taping. Thanks to all for the invaluable advice! |
| MARKS2RR Member Since: 29 Aug 2014 Location: Lancashire Posts: 12
Same fault here. soldered and tape it, job done.
| cliffc Member Since: 30 Dec 2013 Location: lichfield Posts: 50
Had the same problem on my 2011 TDV8 this week. Solved in 10 minutes thanks to this forum |
| Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420
Same thing here yesterday...problem solved in 10 minutes!!! |
Same thing happened again last week and the original wire has snapped at the point it enters the rubber grommet at the top of the strut. Bit the bullet and got a replacement part (LR Part LR032839). Piece of pee to fit and all done in 15 mins. And they have improved the quality of the wire significantly. By the way the kit comes with crimp connectors for joining to the old loom.
| Quixotic Member Since: 28 Apr 2015 Location: Florida Posts: 1
anyone know of a module or fuse for the adaptive dynamics in a 2010 RR SC? I eliminated the intermittent fault about 6 months ago by replacing the wires to the shock towers however after 2 weekends of heavy wheeling the dynamics fault is back and is constant. I checked wires and seem okay. any help here is appreciated. BTW this photo is from the 2015 SCARR rally and it was a blast.
| Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142
Just had mine go too |
| silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84
Just had the same problem with mine.
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
Me too |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
just had a look at mine and they have fitted the updated parts to the 2012, the wires coming into the rubber grommets aren't wrapped in tape, they are a thicker rubber cable. so hopefully this won't be a problem |
What a poor design.
