![]() | Home > Maintenance & Mods (L322) > rear dampers on 3.6 tdv8 2007 |
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 56 ![]() ![]() ![]() |
Do not need help anymore, took a while but I eventually found the top of the dampers after having removed more of the interior than needed. Will supply pictures shortly actually very easy to replace both dampers 07 Vogue SE Java Black 3.6 TDV8
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Pics would be appreciated.
I will put pictures on later today. Quite a coincidence I am speaking to my daughter on Skype she stays in Brisbane 07 Vogue SE Java Black 3.6 TDV8
Yes both shockers are the same 07 Vogue SE Java Black 3.6 TDV8 Black Leather heated/ cooled seats Piano black trim deployable side steps L405 Autiobiography 2017 Santorini Black with black pack 13 L405 4.4 Autobiography |
I needed to change the rear dampers on my rr, after obtaining advice from a so called expert |
Isn't it amazing how things happen in clusters |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
I also need a pair of rear shock absorbers... |
It's all happening here with G20. hopefully not as much action as happened in London. |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
What is the likely price to fit two new rear shock absorbers? (supplementary question - are they different parts to the airbag spring units, or integral?). I had an MOT advisory of an oil weep on one of my rear shocks, so am interested.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Rear shocks are separate from air bags, if you do it yourself, do not let the suspension wishbone fully off support when removing the shock, this will put the full pressure on the airbag and you could damage it, the shock controls the amount of drop on the suspension so taking it off means the airbag can burst, the book says you should depressurise the suspension on the corner your doing but this isn't really necessary if your careful....
Thanks, that's helpful. Which brand should I use when replacing (or which to avoid)?
Originals are Bilstein, have a look here....
Haylands - top man, thank you.
Even cheeper;
