Home > Maintenance & Mods (L322) > rear dampers on 3.6 tdv8 2007
Watty
Scotland 2017 Range Rover Autobiography SDV8 Santorini Black
Has anyone changed the rear dampers, any help please 07 Vogue SE Java Black 3.6 TDV8
Black Leather heated/ cooled seats
Piano black trim deployable side steps
L405 Autiobiography 2017
Santorini Black with black pack
13 L405 4.4 Autobiography
Post #289555 29th Oct 2014 2:47pm
Watty
Rear dampers
Do not need help anymore, took a while but I eventually found the top of the dampers after having removed more of the interior than needed. Will supply pictures shortly actually very easy to replace both dampers 07 Vogue SE Java Black 3.6 TDV8
Post #289668 29th Oct 2014 11:11pm
rar110
Pics would be appreciated.
Is the shock the same left and right?
Post #291809 9th Nov 2014 1:04pm
Watty
I will put pictures on later today. Quite a coincidence I am speaking to my daughter on Skype she stays in Brisbane 07 Vogue SE Java Black 3.6 TDV8
Post #291810 9th Nov 2014 1:23pm
Watty
Yes both shockers are the same 07 Vogue SE Java Black 3.6 TDV8
Post #291811 9th Nov 2014 1:24pm
Watty
I needed to change the rear dampers on my rr, after obtaining advice from a so called expert Mad Mad I started to strip out both sides of the boot interior after about 2 hours I found that this was a waste of time. as I still could not get to the top of the strut.
After a few cups of tea I realised I was looking in the wrong place.
So here is how to do it properly and easily
I had the benefit of the use of a vehicle 2 post lift
Before lifting crack the wheel nuts. lift the vehicle and remove the rear wheels, this gives access to the long bolt that passes through the bottom of the damper, remove the nut but leave the bolt in place.
Lower the vehicle, and support under the suspension arm open the boot and remove the spare wheel cover
[img]
Then look closely at the far away right and left corner and you can just see the top of the strut peeking out from under the carpet
[img]
[/img]
To gain access I cut the carpet, it is the easy to remove the 3 nuts holding the damper in place,, then remove the long bolt at the bottom of the damper, gently lower the suspension arm and the damper drops out.,
I hopes this helps someone out
Somehow all the photos are in my gallery 07 Vogue SE Java Black 3.6 TDV8
Post #291861 9th Nov 2014 7:12pm
Isn't it amazing how things happen in clusters Shocked I have a weeping near side rear damper and have just ordered two from the UK , I was going to ask how to do this and along comes this post Thumbs Up 2008 MY Supercharged
Post #291919 10th Nov 2014 1:03am
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
I also need a pair of rear shock absorbers... Sheep
Post #291921 10th Nov 2014 1:40am
rar110
It's all happening here with G20.
hopefully not as much action as happened in London.
Post #291979 10th Nov 2014 1:38pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
What is the likely price to fit two new rear shock absorbers? (supplementary question - are they different parts to the airbag spring units, or integral?). I had an MOT advisory of an oil weep on one of my rear shocks, so am interested.
Cheers, fanders
Post #291984 10th Nov 2014 2:09pm
Rear shocks are separate from air bags, if you do it yourself, do not let the suspension wishbone fully off support when removing the shock, this will put the full pressure on the airbag and you could damage it, the shock controls the amount of drop on the suspension so taking it off means the airbag can burst, the book says you should depressurise the suspension on the corner your doing but this isn't really necessary if your careful....
It's a pretty quick job, shouldn't take more than an hour to do both.
They should be replaced in pairs.
Don't buy cheap ones, they don't last.... Pete
Post #292006 10th Nov 2014 4:26pm
fanders
Thanks, that's helpful. Which brand should I use when replacing (or which to avoid)?
fanders
Post #292008 10th Nov 2014 4:33pm
Originals are Bilstein, have a look here....
http://www.island-4x4.co.uk/rear-shock-abs...-7920.html Pete
Post #292024 10th Nov 2014 5:58pm
Mark L
Haylands - top man, thank you.
That was my next question! Very Happy
Post #292027 10th Nov 2014 6:23pm
Even cheeper;
http://britishparts.co.uk/products/135464-...-RPD500760 2008 MY Supercharged
Post #292134 11th Nov 2014 3:02am
