Home > Technical (L322) > Fuel gauge indication wrong?
x-box
Hi Chaps , need your advice and help please.
Today I pull out 2012 4.4 tdv8 very quickly at the busy and very sharp junction, this junction is very sharp almost 180 degree and I turned very quick can feel the body roll significantly.
Before that I noticed the fuel has about 75% left and after the turn it shows about 25% left. I stopped and fuel up, the fuel pump automatically stopped after I filled in 30 liter and I checked the fuel gauge which shows 45%.
I think the fuel tank is full but the fuel guage only show 45%, what could be the problem?
Many thanks in advance
Regards
Henry.
Post #290277 2nd Nov 2014 3:41pm
In tank fuel sender/pump possibly, mine had a bit of an episode earlier in the year where it was inconsistent, the pump and the sender are in one unit for the 08my and possibly safe to assume that same for 2010->.
As it is a saddle type tank either side of the prop shaft, There are 2 level floats and the dash takes an average reading from the 2 to give level. If one has gone then it confuses the system.... There is nothing that can't be fixed with a hammer😜😜
Post #290285 2nd Nov 2014 4:11pm
x-box
Many thanks, is it a common fault or not so common?
Post #290297 2nd Nov 2014 5:20pm
miggit
Sounds like you've lost a float off the sender in the tank Yesterday I couldn't spell Engineer... Today I are one!
Post #290299 2nd Nov 2014 5:26pm
Not a really common problem, but a few have had trouble with fuel readings. Bit of a pain to get out. Ordered a pump unit of lrdirect and got dealer to fit it. Saved a few hundred squids. Would investigate further before splashing out though as the units aren't cheap.! There is nothing that can't be fixed with a hammer😜😜
Post #290303 2nd Nov 2014 5:48pm
x-box
My car is still under warranty, will this be covered by?
Post #290321 2nd Nov 2014 7:14pm
I would have thought so on the lr warranty, not really a wear and tear kinda problem.... There is nothing that can't be fixed with a hammer😜😜
Post #290322 2nd Nov 2014 7:17pm
x-box
Many thanks for your advice, will call dealer tomorrow
Post #290323 2nd Nov 2014 7:43pm
x-box
Got the car from dealer last night, it's the connector's problem, they say they modified the wiring, it's fine now. Hope it remain fine.
Many thank or ur help here guys.
Regards
Henry
Post #291545 8th Nov 2014 8:15am
