Home > Technical (L322) > FBH again! Which Battery?
Page 2 of 3 <123>
all in the wiki.. Thumbs Up ... - .- -.
Post #290520 3rd Nov 2014 10:16pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Ah, yes, TA. Bow down
Post #290521 3rd Nov 2014 10:17pm
Discotigger
The pairing sequence/instrctions should be in the handbook for the webasto heater.
If you havent got the handbook, you can download the pdf version from the Webasto website. A handy tip, though, rather than trying to find and pull the fuse they talk about in the handbook, just pull the power lead from the top of the remote receiver wait and replace the lead then press the required button(s) on the fob.
It might take a couple of attempts for the pairing to work, so be patient.
Good luck, the remote fobs are brilliant once you've got them working, especially on cold, dark and wet mornings (like this morning!!)! Thumbs Up
Post #290525 3rd Nov 2014 10:22pm
Discotigger
DOH, beat me to it again Laughing
Post #290526 3rd Nov 2014 10:22pm
Lad
Thanks. Is that why the light on the fob is flashing really quickly for about 2-3 secs?
Its not paired.
Post #290529 3rd Nov 2014 10:26pm
Discotigger
That's a good possibility. Try the pairing procedure, as I said it may take a few attempts but be patient, but get a new battery as well. The fobs can be temperamental with older batteries.
Post #290532 3rd Nov 2014 10:42pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
FYI
Best I can do at this time of the morning Thumbs Up
Post #290562 4th Nov 2014 4:58am
Lad
Ta. I'll have a look later. Can't really make out which panel or module I'm meant to be unplugging, sorry guys. Embarassed It didn't fire this morning after being set to come on at 7am. The outside temp was 4 degrees. Any pointers on that?
Post #290586 4th Nov 2014 11:50am
Discotigger
There may be another fuse in the glovebox fusebox, should be a 20amp fuse for auxiliary heater. Maybe worthwhile having another look in the handbook.
The handbooks seem to vary in fuse layout between different model years, but I would think there would be 20amp fuse for the FBH itself and a 5amp fuse(s) for the receiver and timer units.
I've got some photos at home of the FBH receiver and the plug to be pulled, will try and upload them tonight when I get back from work.
Post #290603 4th Nov 2014 1:31pm
Lad
Ta. I looked at the handbook and it said 5A number 16 in the rear compartment, which I thought was a low ampage. So is there another fuse in the front under the passenger glove box I may need to look at?
I'm still hoping its a simple fuse, as nowt is working. Got the remote working now. Green light steady on then turns to steady slow flashing but kept flashing slowly and I counted over 20 slow flashes until I pressed off and then it showed red. So the rapid flasing amber light must mean low battery.
Post #290604 4th Nov 2014 1:36pm
J evro
Have a look here mate , may help
http://www.fullfatrr.com/forum/topic27290.html
And glovebox fuse is number 59 @ 20a
Also I read somewhere on here recently if you have attempted to start the FBH 3 times or more and not been successful the system locks out and needs to be unlocked by the dealer or someone with a diagnostics tool ?
Post #290650 4th Nov 2014 4:48pm
Lad
Cheers. I looked in the handbook and couldn't find the appropriate aux heater fuse. Just looked in the handbook and it says fuse 59 is spare. I'll go and look on the car tho as they are not always correctly written these handbooks Thumbs Up
I took out the rear fuse and I thought hhhhmmmm looks a nice gap to lose one down......... And off it went down the gap. I replaced it with another and then pressed off on the remote but it didn't do owt. I'll read the above link too after checking the fuse in the car. Thanks Thumbs Up
Post #290662 4th Nov 2014 5:46pm
Lad
Hhmmmm I've checked the fuse 59 and there is no fuse in there Shocked now on the board that covers it it also doesn't have a symbol to show what goes in there. Is it possible I ain't got a FBH on my range rover Shocked
I thought all diesels had them and that's one of the things that swayed me towards the diesel than a supercharged. Evil or Very Mad
I'm confused now.
Post #290663 4th Nov 2014 5:53pm
Lad
Looks like I've paired the remote as I pressed on and the fans came on inside the car. 8 degrees outside. Just wondering about this missing fuse 59. Confused
Post #290671 4th Nov 2014 6:15pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Chances are the heater is locked out, it has its own w bus control.
An iid tool or alike can reset. It can be anything from trying to start 3 times with the fuel light on to a dodgy glow plug, faulty pump etc.
Mine doesn't wok at the mo, when i get the iid all will be clear.
My disco 3 had the same issue, locked out due to failed starts. One test purge with the iid and all was well.
Steve
Post #290693 4th Nov 2014 7:22pm
Page 2 of 3 <123>
