![]() | Home > Technical (L322) > FBH again! Which Battery? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
all in the wiki.. |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Ah, yes, TA. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
DOH, beat me to it again ![]() |
Thanks. Is that why the light on the fob is flashing really quickly for about 2-3 secs?
That's a good possibility. Try the pairing procedure, as I said it may take a few attempts but be patient, but get a new battery as well. The fobs can be temperamental with older batteries. |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
FYI
Ta. I'll have a look later. Can't really make out which panel or module I'm meant to be unplugging, sorry guys. |
There may be another fuse in the glovebox fusebox, should be a 20amp fuse for auxiliary heater. Maybe worthwhile having another look in the handbook.
Ta. I looked at the handbook and it said 5A number 16 in the rear compartment, which I thought was a low ampage. So is there another fuse in the front under the passenger glove box I may need to look at?
Have a look here mate , may help
Cheers. I looked in the handbook and couldn't find the appropriate aux heater fuse. Just looked in the handbook and it says fuse 59 is spare. I'll go and look on the car tho as they are not always correctly written these handbooks |
Hhmmmm I've checked the fuse 59 and there is no fuse in there |
Looks like I've paired the remote as I pressed on and the fans came on inside the car. 8 degrees outside. Just wondering about this missing fuse 59. |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Chances are the heater is locked out, it has its own w bus control.
