Home > Technical (L322) > Steering column reach and tilt mod state (plastic/brass nut)
Robbo63
England 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Hi
I'm looking to acquire a 57 plate Vogue SE with a tilt fault. The motor is still running but stuck in the full up position. No clicking noises etc, just a smooth sounding motor. Does anyone know what I might find if I were to quietly whip off the lower 'cowl'? I know there were recalls on previous models but don't know what mod state a 57 plate might be. Hoping It would be a plastic nut issue but suspect these were modded out. Is there a clutch mechanism in the motors?
Hoping someone can shed some light. Many thanks
Robbo
Post #290535 3rd Nov 2014 10:47pm
Without looking its hard to comment! There are plastic clips that hold the motors on the column that fall off... Torque tubes that run from the motor to the column... Thats if your lucky! If your not then there's brass parts (and others) that break rendering the column unserviceable!!! If this happens, there is a chance you can wind the column to your desired height using a 13mm spanner...
How often do you change the height anyway?
Just be aware though sir... A new column is a small fortune! £1300 + Thud
Post #290558 4th Nov 2014 1:59am
Robbo63
Thanks. It doesn't flop about, just the motor spinning. I've read elsewhere that the plastic pinion gear can slip on the motor shaft as if a clutch were slipping. I've seen the cast lugs that can shear off an get messy. Far from a good design:-/
Post #290564 4th Nov 2014 7:40am
Weegie
This US site has some info:
http://www.rangerovers.net/repairdetails/s...troduction John
GAP iiD BT-Sold
Post #290573 4th Nov 2014 9:44am
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
It may be worth speaking to Ian at IAWA - not too far from you if you are Midlands - I noticed that he advertises that he fixes this problem on L322s: http://iawaclassicsand4x4.co.uk/Range-Rover-L322-02-09.php 4.2 Supercharged Vogue SE
Post #290700 4th Nov 2014 7:46pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
??????????????? 150GBP for oilservice at a old RR TD6 ?????????????????? I offer here in Germany oilservice, incl. Pollenfilter, airfilter, breatherfilter and the Dieselfilter all. incl. 180 Euro, that are 140 GBP......, for the TDV8 I offer the same for 210 GBP....., and I earn lot of money with this service ,-))) L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #291300 6th Nov 2014 10:44pm
Meerbusch
... and the steering column problems are normal work, easy job, no problem like some garages are here writing ...., only the bracket QYH500030 becomes expensive actuall L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #291301 6th Nov 2014 10:46pm
steptoe
That's the reason why i've used the IID diagnostic to turn off the steering column return when igntion is turned off/on..
Heard stories of it getting stuck. So figured if the motor doesn't have to move each time the ignition is turned on and off it must save wear and tear on the motor Very Happy
Post #291389 7th Nov 2014 1:08pm
