![]() | Home > Technical (L322) > FBH again! Which Battery? |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Just been out and had a look at my fusebox, have a look for a legend that looks like an engine with three squiggly lines in the centre of it. That's the legend for the FBH, plus should have a 20amp fuse associted with it. |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
I did have a look on the board didn't see anything jumping out. I'll look again tomoz in daylight. When I was looking at the thread pairing the remote in the back of mine, it looked different. To remove the fuse box there are 2 hex head nuts not the other kind. Got it paired anyway. But maybe the fuse box in the passenger glovey may be a different layout.
Ok. The timed climate didn't come on this morning, so I plipped the little heater remote whilst next to car, and fan my brow, it fired up. It ran until I got in and set off, but it didn't run its full cycle, but it had cleared the windscreen and side windows and slightly warm inside. |
Does everything else work on your satnav system? There is another fuse that powers the satnav, including the timed heating, but I would have thought if you could access the timed heating on the satnav screen, then the fuse should be okay. That's the only other thing I can think of, apart from is the clock working properly? |
Yes the satnav fully works. I can get to the timed climate and set it for 7am. It's in 12hr mode so shows am/pm. The clock is showing correct time too. I'll try the plipper in the morning when I wake up. I'll have another play tomoz too. |
