Home > Technical (L322) > FBH again! Which Battery?
Page 3 of 3 <123
Discotigger
I believa all diesel vogues have th FBH as standard, don't thnk it's an option except on petrol RRs.
I'd check all the legends on the fuse box lid, that may give you a clue.
I'll ry and dig out some of the newer manuals and see what possible fue number it could be,
Also, shove a spare 20amp fuse into position 59 on the fusebox and see what happens. Position 59 is only for the fbh, so if you don't have a fbh fitted (highly unlikely if it's a doozel) nowt will happen.
Post #290694 4th Nov 2014 7:23pm
Discotigger
Just been out and had a look at my fusebox, have a look for a legend that looks like an engine with three squiggly lines in the centre of it. That's the legend for the FBH, plus should have a 20amp fuse associted with it.
Post #290698 4th Nov 2014 7:33pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
I did have a look on the board didn't see anything jumping out. I'll look again tomoz in daylight. When I was looking at the thread pairing the remote in the back of mine, it looked different. To remove the fuse box there are 2 hex head nuts not the other kind. Got it paired anyway. But maybe the fuse box in the passenger glovey may be a different layout.
I'll look tomoz.
Post #290725 4th Nov 2014 9:07pm
Lad
Ok. The timed climate didn't come on this morning, so I plipped the little heater remote whilst next to car, and fan my brow, it fired up. It ran until I got in and set off, but it didn't run its full cycle, but it had cleared the windscreen and side windows and slightly warm inside. Thumbs Up
Just can't understand why the timed bit didn't kick in Rolling Eyes
Thanks for your replies up to now, never know things can still go wrong Laughing
Post #291012 5th Nov 2014 7:41pm
Discotigger
Does everything else work on your satnav system? There is another fuse that powers the satnav, including the timed heating, but I would have thought if you could access the timed heating on the satnav screen, then the fuse should be okay. That's the only other thing I can think of, apart from is the clock working properly?
Post #291021 5th Nov 2014 8:13pm
Lad
Yes the satnav fully works. I can get to the timed climate and set it for 7am. It's in 12hr mode so shows am/pm. The clock is showing correct time too. I'll try the plipper in the morning when I wake up. I'll have another play tomoz too. Thumbs Up
Post #291039 5th Nov 2014 9:58pm
Page 3 of 3 <123
