![]() | Home > General > Fog light out? |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Think if it ain't a fuse or a bulb it's new fog light fitting time.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
I think they are 'sided' so maybe you can swap the other one over to check to see if it works with the connector in, then you'll know if its the unit or a wiring issue. Discovery 4 HSE
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I have a fog light out, good idea about switching them over, I'll try that to (If it's not immiediately obvious where the problem is) |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
I had a front foglight problem on my old TD6 - the electrical conection block to the light unit had become corroded (green and furry) - after a quick clean up it did work for a short time, then failed again, so was fixed under warranty. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
when i changed my fogs to drl's i found the back of the fog units very corroded and dirty ,might be worth a clean like DELAMO says.. ... - .- -.
Another job to do this weekend!
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Changed/ swopped bulbs and have by passed the connector block and still not working. Does anyone know where the fuse is and are they sided? Did google/search to no avail! |
have you looked at RAVE... ... - .- -.
Now downloading!! |
Download didn't work. wheres the most reliable/ safe place to download RAVE or can you buy it on cd??
have you tried here.
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Also if you have a screen saver enabled to come on on your pc switch it off before you start a large download, i have found that sometimes the screensaver coming on can stop the download when downloading large files 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
green oval is where i tried. Screen saver a good tip, will try again, as still unsure why fog light out!! |
Still not managed to download! Says i need a disc to save to which i don't have!!
