Home > General > Fog light out?
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Fog light out?
Hi, Passenger side fog not working. Swopped bulbs, checked wiring and no joy. Couldn't find fuse but could this be the case as only one out?? If so where am i checking for fuse or any ideas guys??
Post #29073 23rd Sep 2010 8:50pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Think if it ain't a fuse or a bulb it's new fog light fitting time.
May be worth using a multimeter and testing if powers getting there. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #29074 23rd Sep 2010 8:53pm
I think they are 'sided' so maybe you can swap the other one over to check to see if it works with the connector in, then you'll know if its the unit or a wiring issue. Discovery 4 HSE
1993 90 Tdi
Post #29081 23rd Sep 2010 9:35pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I have a fog light out, good idea about switching them over, I'll try that to (If it's not immiediately obvious where the problem is) Smile
Post #29217 24th Sep 2010 1:31pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
I had a front foglight problem on my old TD6 - the electrical conection block to the light unit had become corroded (green and furry) - after a quick clean up it did work for a short time, then failed again, so was fixed under warranty.
Post #29220 24th Sep 2010 1:38pm
when i changed my fogs to drl's i found the back of the fog units very corroded and dirty ,might be worth a clean like DELAMO says.. ... - .- -.
Post #29227 24th Sep 2010 1:44pm
Richcl
Another job to do this weekend!
Smile
Post #29229 24th Sep 2010 1:48pm
Nickj
Changed/ swopped bulbs and have by passed the connector block and still not working. Does anyone know where the fuse is and are they sided? Did google/search to no avail!
Post #29314 24th Sep 2010 10:19pm
have you looked at RAVE... ... - .- -.
Post #29320 25th Sep 2010 9:06am
Nickj
Now downloading!!
Post #29379 25th Sep 2010 5:46pm
Nickj
Download didn't work. wheres the most reliable/ safe place to download RAVE or can you buy it on cd??
Does anyone know where the fuses are for fogs? there not under glove box?
Post #31934 15th Oct 2010 7:19pm
have you tried here.
http://green-oval.com/joomla/index.php?opt...;Itemid=29 ... - .- -.
Post #31982 16th Oct 2010 9:34am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Also if you have a screen saver enabled to come on on your pc switch it off before you start a large download, i have found that sometimes the screensaver coming on can stop the download when downloading large files 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31989 16th Oct 2010 10:32am
Nickj
green oval is where i tried. Screen saver a good tip, will try again, as still unsure why fog light out!!
Post #32143 17th Oct 2010 7:54pm
Nickj
Still not managed to download! Says i need a disc to save to which i don't have!!
Anyone know where the fuse for the fogs are as i can't find them. Not under glove box or rear compartment! Any other fuse boxes?
Post #36580 17th Nov 2010 7:05pm
