Home > Technical (L322) > FBH interesting device sent to turn you mad help please |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2224 |
Gents before I go and put it into the stealers any ideas the fhb runs can hear the fans and a clicking from the offside rear but no heat it starts from the fob stops from the fob but no heat ?? Fault code thrown up by IID is 0x0B08 Flame out
4th Nov 2014 1:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34945 |
heater switch's turned on to max and vents open?..obvious but you never know...
4th Nov 2014 2:28pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Like Stan says - - unusual for petrol and do you really need it anyway?
4th Nov 2014 3:09pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
Have a look at this,it may give you a better idea of what's wrong
4th Nov 2014 9:02pm |
To be honest it is as has been said because it is there I need it to work I have this thing about having no faults - mad I know - but do like everything working. Will have a read up and if no good into the stealers - still have JLR warranty till feb |
4th Nov 2014 9:59pm |
Could probably be something the dealer needs to look at, possibly the ecu. Get them to fix it. I spent hours trying to get mine to work, in the end the dealer just put a new on in under warranty! All toasty now. There is nothing that can't be fixed with a hammer😜😜
5th Nov 2014 12:06am |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
The dealer put a new unit under warranty in my L322 as well and it still didn't work (blowing cold air instead of hot). Very annoying but someone else's problem now. |
5th Nov 2014 7:56am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Flame out would suggest that there is a problem with the ignition system in the heater, or the thermocouple that senses the flame is not functioning. A common occurrence on gas appliances, and as a result that can be replaced for under a tenner. But as for a FFRR, you have the Land Rover factor to add into the cost. I believe that the units are made by Webasto, it might be worth talking to them. As I cannot for one moment see a Land Rover technician stripping the heater and replacing a thermocouple, so it would be a service exchange or replacement. The other place to look for help might be your local Boat Marina, than type of heater is very common on a boat. Yesterday I couldn't spell Engineer... Today I are one!
5th Nov 2014 11:45am |
If you can be bothered to take it out there are instructions on the net how to service and repair them, search for webasto thermotop, they are pretty simple pieces of kit really but seem prone to problems when not used over the summer. There is nothing that can't be fixed with a hammer😜😜
5th Nov 2014 11:30pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Diesels have them to help warm up the coolant system for the engine, which in turn helps to warm up the cabin. .
6th Nov 2014 12:21am |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
Imo it's the PCB. Another one for French mike me thinks |
7th Nov 2014 5:33pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Nearly but a bit more complicated than that , when turned on by the fob or timer the heater closes a valve in the coolant system and all the heat should go to heating the cabin and once the engine is turned on if the the computermebob thinks it is cold enough it will continue to run to bring the engine up to thermal efficiency quicker , this is on the TD6 on the TDV8 I believe this was dispensed with but I can't quite remember so don't quote me on that . This valve I mentioned earlier can fail leading to some specific problems of heaters running but not heating sufficiently and on petrol versions it is just a cabin heater ( not much use to me in Western Australia). 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
8th Nov 2014 7:19am |
Don't worry Axle, you will be needing heating soon when the WA winter hits. I remember in Lagos during Harmatan (dry season) it got down to 21 and I had to turn on the seat and steering wheel heaters because I was cold and that is no joke !!! My "normal" setting in the car and house is 25 C !! MY 2010 5.0 SC Galway green and sand interior!!
8th Nov 2014 8:18am |
I know mate , I'm just waiting for the day I start bitching about it getting below 15º C .When I show people the switch on the staring wheel for heating they look at me like I'm barking mad Poofters here would't last ten minutes on a summers day in Argyll let alone winter . 2008 MY Supercharged
8th Nov 2014 9:09am |
