Home > Technical (L322) > headlight
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
headlight
Hi all, my nearside headlight keeps going out after about 5 minutes of driving,it flickers first then goes out, but if you turn the lights off and then on it works again, any body got any ideas please as its doing my nut in Mad .
thanks in advance. gone fishin'
Post #290988 5th Nov 2014 5:41pm
could be the ballast but i would swop bulbs over first and see if it still happens.. ... - .- -.
Post #290992 5th Nov 2014 5:43pm
Discotigger
Probably the bulb on its way out. As Stan (the man!) said, swap the bulbs over and that will confirm if it is the bulb that's dying. I had the same problem and it was the bulb, not the ballast (thankfully), that was going.
Just remember it's advised to replace both HID bulbs at the same time, you can always keep the good one as a spare.
Also, if you've got the 4800k bulbs (fitted as OEM on most Full Fats) it could be worthwhile getting the 6000k bulbs as they give a crisper white light compared to the yellowish tinge of the standard HID bulbs.
Post #291023 5th Nov 2014 8:22pm
Re: headlight
thanks in advance.
I have some used ones sir Thumbs Up
Post #291096 6th Nov 2014 12:08am
andyboy
I will swap them on the weekend and see what happens, I will let you know Craig
Thumbs Up thanks peeps gone fishin'
Post #291258 6th Nov 2014 7:49pm
Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post #291284 6th Nov 2014 9:48pm
