![]() | Home > General > Vogue SE or Vogue with an 'extra' badge?! |
Welcome to the best and friendliest RR forum Robbo,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
The factory rse is recessed into the headrest, you can normally tell a vogue se by the 2 knobs either side of the clock. The vogue has none and the control for the heated seats is on the temp dials.
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
The other big giveaway for an SE is perforated leather along with the cooled seats |
Robbo63 Member Since: 03 Nov 2014 Location: Midlands Posts: 28 ![]() ![]() ![]() |
Thanks for the replies:-)
It has the Venture Cam and some connector in the armrest that I'm assuming is for the phone, side steps, auxiliary heater and removable tow bar. Looking at the images in the Ad http://www.fullfatrr.com/forum/topic12944.html?highlight=vogue+se it looks identical apart from the seats, missing knobs either side of the clock and the badge misalignment.
You can check with LR, they will know how it left the factory but I can tell you, having owned an 07 VSE that the 2 knobs either side of the clock are for the heated and cooled front seats. Without this it would be a Vogue.
No venture cam on my vogue Dom.......
I think the TDV8 badge has been moved too as it doesn't match anything else on t'internet. I don't know if the headlights look round corners, is it obvious to see? I'll call the garage tomorrow and get the VIN and call it through. Does anyone on here have access to the LR records or can I just call LR?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6824 ![]() ![]() ![]() |
No cooled seats = not an SE! |
Many thanks for all of your replies, much appreciated. I'm quite dubious about its history so will give it a wide berth (although could buy it and kick off with them as a dealer!!)
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8090 ![]() ![]() ![]() |
Be careful - just to confuse things, there's an SE as well as a Vogue SE ![]() It could be an SE with a Vogue badge added ![]() |
I assumed the "vogue" bit would be unnecessary in the context of the question |
