Home > Maintenance & Mods (L322) > Steering wheel removal
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Guys
I'm fitting a new steering wheel Sat. I have read Stans Wiki on removing the battery. And also the post about removing the air bag with a slim screwdriver and a wiggle.
Once removed (I'll spray the spokes silver) is the steering wheel on a fine or course spline? Mine is about 1-2 fine splines out to the left so was hoping to move it around 1-2 teeth.
Will this cause me grief when I reconnect it all and do the full lock left and right learning thing?
Is there anything other than the clock that looses memory? I.e radio codes or windows etc?
Cheers in advance.
Tel Accept, some days your the pigeon, some days your the statue!
Post #292042 10th Nov 2014 7:35pm
n1cktdv8
if your moving the wheel round, have you checked alignment and track etc ?? Is this where I put the car details and a bit about myself ?........
Post #292058 10th Nov 2014 8:11pm
Boydonegood
TBH the steering wheel has been off since I brought it. Only by 1-2 fine splines (if it has them?)
Car doesn't pull to the side and tyres are wearing even. So hoping it's been put on slightly off at sometime. Accept, some days your the pigeon, some days your the statue!
Post #292061 10th Nov 2014 8:18pm
Unlikely the wheel is off TBH, more likely the straight ahead is out on the tracking, last time it was tracked the steering wheel probably wasn't set straight....
Best to straighten it up with the track rods not simply move it round a spline or 2, they aren't that fine an adjustment. There is nothing that can't be fixed with a hammer😜😜
Post #292071 10th Nov 2014 9:07pm
Boydonegood
Damn I knew someone would suggest I get dirty!! Wink
Will have a go at cracking the ballpoints and giving them both a turn or 2 to see.
Cheers
Post #292082 10th Nov 2014 9:39pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
To answer your other points, the radio will lose presets but won't need a code or anything, of course your MPG/trip mileage etc will go as well, aside from that, each time I've had my battery off it's been quite well behaved, never had to reset windows or sunroof etc.
Usually just lock to lock for the adaptive headlights.
Good luck!
Steve
Post #292085 10th Nov 2014 9:47pm
Boydonegood
Thanks guys.
Appreciate it!! Thumbs Up Accept, some days your the pigeon, some days your the statue!
Post #292086 10th Nov 2014 9:48pm
Any garage that knows what they are doing will set the steering wheel straight, lock it off with a seat clamp and then adjust the alignment, if your steering wheel isn't straight it would suggest that it hasn't been done properly, I would get it checked to make sure, most garages will check it for free and only charge if adjustment is needed.... Pete
Post #292126 11th Nov 2014 1:04am
