![]() | Home > Maintenance & Mods (L322) > Steering wheel removal |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
if your moving the wheel round, have you checked alignment and track etc ?? Is this where I put the car details and a bit about myself ?........ |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
TBH the steering wheel has been off since I brought it. Only by 1-2 fine splines (if it has them?)
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Unlikely the wheel is off TBH, more likely the straight ahead is out on the tracking, last time it was tracked the steering wheel probably wasn't set straight....
Damn I knew someone would suggest I get dirty!! |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
To answer your other points, the radio will lose presets but won't need a code or anything, of course your MPG/trip mileage etc will go as well, aside from that, each time I've had my battery off it's been quite well behaved, never had to reset windows or sunroof etc.
Thanks guys.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8794 ![]() ![]() ![]() |
Any garage that knows what they are doing will set the steering wheel straight, lock it off with a seat clamp and then adjust the alignment, if your steering wheel isn't straight it would suggest that it hasn't been done properly, I would get it checked to make sure, most garages will check it for free and only charge if adjustment is needed.... Pete
