![]() | Home > Maintenance & Mods (L322) > Tow Bar Height Grrrr !! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I don't want to rain on your parade bud, using a trailer in the UK without a breakaway function is illegal, and by saying that you have no handbrake, means that you can't have a breakaway. As one acts on the other, be very careful that VOSA, or whatever they are calling themselves this week, don't get a hold of you. Cos they'll throw the book at you, and probably issue a prohibition notice on the spot. You'll then have to get it lifted to have it upgraded.. Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Just out of curiosity, is it not the case that where a break-away cable cannot be fitted for whatever reason it is acceptable to fit a chain that links car and trailer with enough strength to keep the two joined should the worst happen? |
That just sounds like recipe for getting run over by your trailer. For me its a risk not worth taking, especially as the bulk of what I tow are Mobile Toilets, would you want to make an insurance claim that begins with "I was going down the road and I got run over by a toilet" . Some how I think that the insurance company would have me down as nuts, and try and wriggle out |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8087 ![]() ![]() ![]() |
Thanks - mine lives in France - secure storage is about 4 miles from the lake on which we use it.
That Department for Transport document is an interesting read but unfortunately finishes in a typically UK style |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
Yes, it's very irritating, particularly with an empty trailer. Lower third of the factory drop plate is also only useful for ploughing practice, and it could do with a bit more clearance between the factory ball and rear bumper on the upper holes (swapped it for a slightly longer ball/jaw that was lying around). |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
when I bought my FF it was a non runner, it had a farmers hitch, (trencing plough) and car was low, ie the bags had gone down. when trying to recover the car, it wouldn't go on the truck, as it was trying to pull out a kerbstone, ie ploughing. no amount of hammering would free it (hitch) . and planks were used eventually, to raise wheels. what a mess! I had to bottle jack out that hitch, against the armature. that's why no-one had nicked it! got hold of a westfalia one and all now good. whatever the lower holes were for I don't know!
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
For some time now all tow bars must be type approved for the vehicle and any modification to the tow bar is not permitted.
They did 3 different versions - I have 2 of them |
Keeps the lawyers in business I suppose 😄 Interestingly the FFRR armature is very similar to the U.S. design except theirs measures 2" and ours is 50mm - so it has the mountings for the crossover chains - if you look, there are two circular holes either side of the receiver. The U.S. system is that you cross the chains under the coupling - then if it comes off, the chains catch it and stop it nosediving- would most likely make a mess of your car if you were braking hard, but IMHO better than a trailer which goes off in a random direction even if it has the handbrake on. |
![]() Please forgive me but all these figures are from memory so don't shoot me if I'm out a tad.....but.....the bolt which is used to secure the hitch is an M16 (Metric Coarse??) and to attain a 90% preload a torque value of approx'' 210 Nm (??) is required. This, should therefore generate a preload of 7te (?? again - could be out). The receiver has a pretty heavy wall and has a brace welded around the opening to prevent the RHS from splitting. I am amazed that LR would consider it plausible to collapse such a section / structure with just 7te (??) of load. I know mine is torqued up fully and at no point did the receiver tighten onto the hitch.. Having said that, despite years of experience, LR can still put the exhaust from the FBH in a position on a £100+k car which has the potential to give the occupants a decent dose of CO ![]() |
I don't want to point out the obvious way around your height issues, but...........
The VOSA guy had a good look at mine on the M5 and he made no comment except that it looked over-engineered, oh and he also asked about the "Bearing Buddies" it has fitted. 2" ball coupling, hydraulic brakes and 2 effing great chains (12000 LBS each). The trailer is also technically too wide to be legal in the UK but this wasn't even measured. In fact the only EU legal bit is the lighting which I modified myself. I have also modified it to have a ratchet handbrake now although there's no breakaway cable on this. And I have to say it is far better engineered than any EU made trailer, especially with the hydraulic brakes being massively smoother than Bowden cable antiques. They went out on cars with the Model T Ford. In every respect, except possibly for galvanising, the American trailer is superior to the EU versions and VOSA are smart enough to know this. Unless you are driving a blatantly unsafe rig, i.e. overloaded, no breakaway chains, ineffective brakes, non-functional lighting etc they will let you be on your way. What they are interested in are overloaded caravans being towed by too small a car, no lights, duff brakes, and by far the worst thing they hate is overloading. That will get you a ticket every time. |
