Home > Maintenance & Mods (L322) > Tow Bar Height Grrrr !!
Page 2 of 3 <123>
miggit
Alistair wrote:
Mines a U.S. trailer - 2" ball, hydraulic brakes and no handbrake Thumbs Up
Yours actually looks like it was modified to sit higher - mine just runs straight from the horizontal trailer box section.
I don't want to rain on your parade bud, using a trailer in the UK without a breakaway function is illegal, and by saying that you have no handbrake, means that you can't have a breakaway. As one acts on the other, be very careful that VOSA, or whatever they are calling themselves this week, don't get a hold of you. Cos they'll throw the book at you, and probably issue a prohibition notice on the spot. You'll then have to get it lifted to have it upgraded.. Yesterday I couldn't spell Engineer... Today I are one!
Post #292089 10th Nov 2014 10:07pm
noworries4x4
The Boston Whalier trailer I pulled for my boss had a ratchet hand brake added to apply the hydraulic brakes and the breakaway was attached to this If everything is under control you are not going fast enough.
MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
MY 12 Full Fat 4.4 TDV8
1952 Series 1 80" 3ltr 6cyl
Post #292103 10th Nov 2014 10:40pm
RiccartonRR
Just out of curiosity, is it not the case that where a break-away cable cannot be fitted for whatever reason it is acceptable to fit a chain that links car and trailer with enough strength to keep the two joined should the worst happen?
Post #292104 10th Nov 2014 10:46pm
miggit
That just sounds like recipe for getting run over by your trailer. For me its a risk not worth taking, especially as the bulk of what I tow are Mobile Toilets, would you want to make an insurance claim that begins with "I was going down the road and I got run over by a toilet" . Some how I think that the insurance company would have me down as nuts, and try and wriggle out Laughing
And thinking about it a chain is only acceptable on a trailer with no brakes, which means that its total mass cannot exceed 750 kg. If a trailer is over 750 kg, it must be fitted with brakes and have a breakaway device fitted and working. And I think you will find that, that is the law, no excuses.
I'm not trying to be a kill joy, I'm trying to save you from a nasty fine, and possible prohibition. Which would result in either the trailer being impounded or it having to totally lifted for removal. And unfortunately trailers do not like going on the back of a normal recovery truck, most cases end up with a low loader and a hefty bill. Yesterday I couldn't spell Engineer... Today I are one!
Post #292124 11th Nov 2014 12:36am
Thanks - mine lives in France - secure storage is about 4 miles from the lake on which we use it.
IMHO the US spec trailers are much better than the European ones - I'd rather have crossover chains than a breakaway handbrake - it's likely to cause far less collateral damage should the worst happen. The brakes are also much better than any cable brakes - but totally understand what you're saying with regards to legality, insurance etc.
DVLA specify "Caravans and trailers fitted with a braking system are required to be stopped automatically if the coupling separates while the trailer is in motion." I guess it's a bit of a grey area as to whether chains would qualify as part of the 'coupling'......
My 2" coupling is also rated for 50mm balls - not sure if the wheel chocks would hold on an 18% gradient....
Full spec here Thumbs Up
Post #292142 11th Nov 2014 4:36am
RiccartonRR
That Department for Transport document is an interesting read but unfortunately finishes in a typically UK style Big Cry
How on earth can the Department for Transport be in the situation where the advice they give is "only their interpretation" of the legislation and that they advise the reader to seek independent advice??
If the government body responsible for Transport can't give definitive advice about transport matters then it is not fit for purpose IMHO.
Post #292150 11th Nov 2014 9:03am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Re: Tow Bar Height Grrrr !!
RiccartonRR wrote:
Once you've used the tow bar you'll notice you can move it up / down / sideway a few mm and it hammers something awful in the car
Yes, it's very irritating, particularly with an empty trailer. Lower third of the factory drop plate is also only useful for ploughing practice, and it could do with a bit more clearance between the factory ball and rear bumper on the upper holes (swapped it for a slightly longer ball/jaw that was lying around).
Post #292166 11th Nov 2014 10:38am
johnboyairey
when I bought my FF it was a non runner, it had a farmers hitch, (trencing plough) and car was low, ie the bags had gone down. when trying to recover the car, it wouldn't go on the truck, as it was trying to pull out a kerbstone, ie ploughing. no amount of hammering would free it (hitch) . and planks were used eventually, to raise wheels. what a mess! I had to bottle jack out that hitch, against the armature. that's why no-one had nicked it! got hold of a westfalia one and all now good. whatever the lower holes were for I don't know!
if you have 'built ' yours up make sure you have some copperslip on the thing!
Post #292169 11th Nov 2014 10:57am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
For some time now all tow bars must be type approved for the vehicle and any modification to the tow bar is not permitted.
For those with the farmer's hitch LR introduced a mod where the pin is replaced by a nut and bolt which is torqued up very high and actually squeezes the outer against the inner, stops all movement and is very quiet.
Ian
Post #292171 11th Nov 2014 11:13am
They did 3 different versions - I have 2 of them Very Happy I leave one in Bordraux after having driven there to find I'd left mine on the garage floor
The first ones has a hole through and a retaining pin - this was then changed for a bolt with a locking pin as well - the final version has the hole in the tow bar piece threaded as well.
I like the pin version as I tend to leave mine off the car when not in use and then don't tow very far - but the threaded version is quieter Thumbs Up
Post #292173 11th Nov 2014 11:36am
Keeps the lawyers in business I suppose 😄
Interestingly the FFRR armature is very similar to the U.S. design except theirs measures 2" and ours is 50mm - so it has the mountings for the crossover chains - if you look, there are two circular holes either side of the receiver.
The U.S. system is that you cross the chains under the coupling - then if it comes off, the chains catch it and stop it nosediving- would most likely make a mess of your car if you were braking hard, but IMHO better than a trailer which goes off in a random direction even if it has the handbrake on.
Post #292174 11th Nov 2014 11:41am
RiccartonRR
Ian
Shocked I have to say I'm amazed at this fact.
Please forgive me but all these figures are from memory so don't shoot me if I'm out a tad.....but.....the bolt which is used to secure the hitch is an M16 (Metric Coarse??) and to attain a 90% preload a torque value of approx'' 210 Nm (??) is required. This, should therefore generate a preload of 7te (?? again - could be out).
The receiver has a pretty heavy wall and has a brace welded around the opening to prevent the RHS from splitting.
I am amazed that LR would consider it plausible to collapse such a section / structure with just 7te (??) of load. I know mine is torqued up fully and at no point did the receiver tighten onto the hitch..
Having said that, despite years of experience, LR can still put the exhaust from the FBH in a position on a £100+k car which has the potential to give the occupants a decent dose of CO Shocked Surely nothing should surprise me!
Post #292181 11th Nov 2014 12:28pm
miggit
I don't want to point out the obvious way around your height issues, but...........
Whistle has anyone tried putting the Flange receiver hitch in upside down? And turning the ball the other way around, would give you a load of holes going up, not down Thumbs Up
I've been towing with a Dixon Bate combi hitch up side down, when towing a trailer with an eye, for donkeys years, to gain height. and as my FFRR has the receiver hitch and I've got a small ladder hitch, bolted to that, I have to option of multiple heights up or down Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #292184 11th Nov 2014 1:10pm
miggit
This is very similar to what I have, and cheap too Thumbs Up
http://www.ebay.co.uk/itm/TOW-BALL-HEIGHT-...43bd526268
I did have to re-drill a couple of the holes, which I did using a 16mm hole saw, through a lot of experience I have found hole saws much better that drill bits for re-aligning offset holes. I actually use an arbor that has a broken drill bit, so that there is no guide drill to get in the way Thumbs Up
Oh and sorry for not showing it on the FFRR, it's in hospital for another gearbox Big Cry , but on a lighter note its a warranty job :D
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Yesterday I couldn't spell Engineer... Today I are one!
Post #292187 11th Nov 2014 1:43pm
mzplcg
miggit wrote:
That just sounds like recipe for getting run over by your trailer. For me its a risk not worth taking, especially as the bulk of what I tow are Mobile Toilets, would you want to make an insurance claim that ..................................................
The VOSA guy had a good look at mine on the M5 and he made no comment except that it looked over-engineered, oh and he also asked about the "Bearing Buddies" it has fitted.
2" ball coupling, hydraulic brakes and 2 effing great chains (12000 LBS each). The trailer is also technically too wide to be legal in the UK but this wasn't even measured. In fact the only EU legal bit is the lighting which I modified myself.
I have also modified it to have a ratchet handbrake now although there's no breakaway cable on this. And I have to say it is far better engineered than any EU made trailer, especially with the hydraulic brakes being massively smoother than Bowden cable antiques. They went out on cars with the Model T Ford.
In every respect, except possibly for galvanising, the American trailer is superior to the EU versions and VOSA are smart enough to know this. Unless you are driving a blatantly unsafe rig, i.e. overloaded, no breakaway chains, ineffective brakes, non-functional lighting etc they will let you be on your way. What they are interested in are overloaded caravans being towed by too small a car, no lights, duff brakes, and by far the worst thing they hate is overloading. That will get you a ticket every time.
Post #292199 11th Nov 2014 2:24pm
Page 2 of 3 <123>
