Home > Technical (L322) > CROSS ARTICULATION FAULT |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
BONG...Slow down to 30 MPH Suspension Fault
13th Nov 2014 2:03pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
has a sensor popped off? Pete
13th Nov 2014 2:05pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1691 |
Incorrect readings from the height sensors.
13th Nov 2014 2:06pm |
They all looked good when I did the front and rear pads a couple of days ago GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
13th Nov 2014 2:07pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6657 |
http://www.lrrforums.com/showthread.php?18...tops/page4
Cheers Mikey...I did adjustments back to my standard height following a green laning day, so wonder if i've up the calibration somehow.
13th Nov 2014 2:09pm |
Cheers Alan...seen those following a google search, but they all seem to have multiple fault codes, whereas I just have the one? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
13th Nov 2014 2:12pm |
Your issue lies in one of those sensors, or respective wiring. The car thinks there is a 70mm difference across the axle, best part of 3 inches, so the car dumps itself down, effectively in suspension "limp mode" Start with a calibration |
13th Nov 2014 2:24pm |
Cheers Mikey...Thought it might be my fault GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
13th Nov 2014 2:43pm |
I done the same with my Disco 3 after playing with the corner heights |
13th Nov 2014 2:49pm |
Leave well alone all...... |
13th Nov 2014 4:55pm |
Not too sure exactly what the sensors are like but I've messed with my heights loads... at first it was a bit finicky and kept throwing up codes and I came to the conclusion it was because although they have a wide range of movement they usually just move a small amount... I took all the rods off and moved the sensor through it's whole movement numerous times, they certainly had more resistance at the ends of their movement, cleaned the electrical connectors and put them back together and not had a problem since... Might be worth a go....
13th Nov 2014 6:39pm |
Had a play this evening and all sorted...As Mikey said, the difference between the rear left and rear right seemed to be the issue.
13th Nov 2014 9:23pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Most height sensors are nothing more than a potentiometer which is a little arm that rubs up and down a carbon track, over the years as the ride height changes, these ware out, quicker now a days with our roads! As they ware out you get false readings from them and the computer overcompensates, until it shuts down, and you get that sinking feeling!
13th Nov 2014 11:16pm |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
sorry to highjack the thread but I have an issue with a height sensor ,according to hawkeye rear left sensor not working. Question is it left from drivers seat or left looking from front of car????? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
15th Nov 2014 11:35am |
