![]() | Home > Technical (L322) > very bad vibration |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Almost certainly the lower control arm needs replaced... Common fault.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I had the control arm replaced 12 months ago when I experienced some minor vibration through the steering wheel on left hand curves. Surely they should last longer than 12 months?
Ah, ok.... It might be worth getting it checked again. Are your wheel nuts tight? Previously..
Yes, no problem with the wheels. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
Did you use Delphi/LandRover or Britpart? |
I don't know, it was fitted by the Garage (Independent Land Rover - Preston) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8772 ![]() ![]() ![]() |
They probably fitted britpart as they are so much cheaper, and you have just found out why.... they just don't last...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8773 ![]() ![]() ![]() |
Check also that the torqued up the bushes when the car was on the ground or a 4 post ramp, not on a 2 post ramp, as this can twist the rubber bushes and seriously reduce the lifespan. There is nothing that can't be fixed with a hammer😜😜
^ yip, as stated in the link I posted above... Previously..
Double yip that happened me plonkers tightened on ramp bush on arm failed prematurely. Present :2008 TDV8 HSE
Sorry |
Lower control replaced yesterday but the problem still exists |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
move your tyres around. you will need another jack. put front left on rear right, and vice versa, this should prove if noise moves across car that its wheel related. tyre could be at fault, or buckled rim... the latter esp.. if aftermarket alloys you could also just use one jack and fit spare wheel on both fronts in turn... |
The vibration affects the whole car and not any specific area. The wheels are standard land rover Westminster style wheels and in as new condition. Surely if the issue was wheel or tyre related the vibration would be felt even when driving in a straight line. I get no vibration at 3 figure speeds in a straight line. |
