Home > Technical (L322) > very bad vibration
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
very bad vibration
Looking for help please.
I'm getting really bad vibration through the whole car when i take slight left hand curves on the motorway at speed. It starts as soon as I apply a very slight left lock on the steering wheel, the whole car starts to shake. As soon as I straighten the wheel it stops. I don't get the problem at normal speeds. It's that bad I have to back off and reduce the speed.
Just had one of the front bushes replaced but the problem is still there.
Sad
Post #293039 14th Nov 2014 8:06pm
Almost certainly the lower control arm needs replaced... Common fault.
Read all of this...
http://www.fullfatrr.com/forum/topic16959....ontrol+arm
Thumbs Up Previously..
Post #293041 14th Nov 2014 8:09pm
Buz1500
I had the control arm replaced 12 months ago when I experienced some minor vibration through the steering wheel on left hand curves. Surely they should last longer than 12 months?
The current problem feels a hell of a lot worse as the whole car shakes.
Post #293043 14th Nov 2014 8:18pm
Ah, ok.... It might be worth getting it checked again. Are your wheel nuts tight? Previously..
Post #293052 14th Nov 2014 8:51pm
Buz1500
Yes, no problem with the wheels.
Post #293053 14th Nov 2014 8:55pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Did you use Delphi/LandRover or Britpart?
Post #293060 14th Nov 2014 9:21pm
Buz1500
I don't know, it was fitted by the Garage (Independent Land Rover - Preston)
Post #293064 14th Nov 2014 9:44pm
They probably fitted britpart as they are so much cheaper, and you have just found out why.... they just don't last...
Original or OEM for all suspension parts, it's not worth the saving... Pete
-Click here for Thread-
Post #293069 14th Nov 2014 9:48pm
Check also that the torqued up the bushes when the car was on the ground or a 4 post ramp, not on a 2 post ramp, as this can twist the rubber bushes and seriously reduce the lifespan. There is nothing that can't be fixed with a hammer😜😜
Post #293143 15th Nov 2014 11:39am
^ yip, as stated in the link I posted above... Previously..
Post #293147 15th Nov 2014 11:54am
Googsy
Double yip that happened me plonkers tightened on ramp bush on arm failed prematurely. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #293169 15th Nov 2014 1:41pm
Sorry Embarassed didn't read the linky.... There is nothing that can't be fixed with a hammer😜😜
Post #293188 15th Nov 2014 3:54pm
Buz1500
Lower control replaced yesterday but the problem still exists Crying or Very sad
Post #294529 21st Nov 2014 1:52pm
johnboyairey
move your tyres around. you will need another jack. put front left on rear right, and vice versa, this should prove if noise moves across car that its wheel related. tyre could be at fault, or buckled rim... the latter esp.. if aftermarket alloys you could also just use one jack and fit spare wheel on both fronts in turn...
Post #294531 21st Nov 2014 2:01pm
Buz1500
The vibration affects the whole car and not any specific area. The wheels are standard land rover Westminster style wheels and in as new condition. Surely if the issue was wheel or tyre related the vibration would be felt even when driving in a straight line. I get no vibration at 3 figure speeds in a straight line.
Post #294538 21st Nov 2014 2:18pm
