![]() | Home > Off Topic > Non Land Rover crank pully bolt removal- advice needed |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I decided today that I was going to try and change the cambelt in my GF Hyundai Coupe. All was going well until I got to the crank pulley bolt. The instructions said, put your impact gun on the pulley bolt and crack it off or shock it off. Bloody thing will not budge, with impact gun and not sure what shock it off is.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
thinking outside the box here , but are you trying to undo the nut in the correct direction ? ... - .- -.
yep, definitely turning it the right way as I have a new bolt to go in so can see it is standard thread 56 TDV8 Vogue SE
Will check the CFM of the compressor as the impact gun always seems a little pathetic. maybe get some new hoses as I am using the ones supplied with the compressor.
You want one of those sprung impact sockets.
