Home > Technical (L322) > Vibration low rpm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Vibration low rpm
Should I be getting worried again??
Had a gearbox recorn'd last year Jan/feb including torque convert
All of a sudden well since up'ing my psi in the tyres I'm getting a vibration in when the car is at temp on low rpm at a certain point like a gear change point, however no errors stored or logged
The car has done nearly 11000 since the recon and is due it's 3rd oil change and filter since refurb
Is there anything else that would cause a judder?? The car is fine on the motorway quicker driving etc it's only low rpm and slow speed it appears
Any suggestions welcomed
Thanks
Neil
Post #293602 16th Nov 2014 9:34pm
cliffy
The vibration is like a stutter even the passenger car feel it
Post #293610 16th Nov 2014 9:41pm
bumpymike
United Kingdom 2006 Range Rover Vogue Td6 Oslo Blue
I once had to change both rear tyres - at low speeds the car felt terrible and my head would be slightly rocking side to side as if the gearbox or propshaft was about to let go.
Both rear tyres had been damaged and the steel inside the casing had shifted to one side causing the tyres to be slightly oval.
At high speed it was no problem.
The tyre company believed it was pot hole damage.
Post #294366 20th Nov 2014 1:49pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
If she does not do it when she is cold it couldn't be the tyres though...
Remember One of mine had that after a TC change. Did a complete gearbox etc flush and it was gone.
Post #294371 20th Nov 2014 2:06pm
Sandyt
Why don't you try lowering your tyre pressure back to how it was before the judder ?
Post #294380 20th Nov 2014 3:15pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
I was going to suggest an injector but yours is a petrol, could it be missing a bit?
My Td6 vibrated very badly at slow speed until I found the faulty one Mine was a blue one! Smile
Post #294389 20th Nov 2014 4:44pm
cliffy
Well guys, its solved it was the gearbox Torque convert, theres something with ZF recon's causing a issue with oil, a additive has resolved it and it drives great again
Post #299729 18th Dec 2014 9:03pm
