![]() | Home > Technical (L322) > Vibration low rpm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
The vibration is like a stutter even the passenger car feel it |
bumpymike Member Since: 29 Jan 2011 Location: Warrington Posts: 2 ![]() ![]() ![]() |
I once had to change both rear tyres - at low speeds the car felt terrible and my head would be slightly rocking side to side as if the gearbox or propshaft was about to let go.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
If she does not do it when she is cold it couldn't be the tyres though...
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Why don't you try lowering your tyre pressure back to how it was before the judder ? |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
I was going to suggest an injector but yours is a petrol, could it be missing a bit?
Well guys, its solved it was the gearbox Torque convert, theres something with ZF recon's causing a issue with oil, a additive has resolved it and it drives great again |
