Home > Technical (L322) > Which remote do I need for FBH on a 55 plate car..
Discotigger
Good to hear jaiscossie Thumbs Up
Just be careful not to use it so much that you flatten the battery, like I did once!!
Had a nice warm vehicle...but couldn't start the engine Rolling with laughter
Post #294029 18th Nov 2014 9:28pm
Heater should fire up below 16deg on the fob👍
Just managed to get mine working on the disco, and it is great to go out to a warm car as the mornings get colder. There is nothing that can't be fixed with a hammer😜😜
Post #294030 18th Nov 2014 9:30pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
I thought it was below 5deg? If I hold the left button on the remote the air circulation comes on. To get the heater to activate should I press the right hand button?
Post #294031 18th Nov 2014 9:39pm
JPS
I read online that you should only use the heater for the length of the journey you are going to do. So a ten mile journey then the heater for 10min before hand
Post #294032 18th Nov 2014 9:40pm
Have a read of the remote instructions, there are 2 modes on the remote, ventillation and heat, I don't know if these are individually selectable on the ff.
If your car is a bit warm it won't kick in the fbh and will just pull the heat from the coolant/latent heat. If it's not kicking in now check the mode on the remote, then try it in the morning, it should fire up. There is nothing that can't be fixed with a hammer😜😜
Post #294036 18th Nov 2014 9:48pm
Discotigger
It's not so much how long you have the heater on before making a journey, but making sure your battery is in good condition and gets a good recharge after using the FBH.
The day I had problems, my battery was on its way out, I was waiting for a work colleague to turn up at my house for a business trip and I was daft enough to pre-heat, reheat and then do one last re-heat to the FF (using the FBH each time, without the engine running). Came to start the engine and...not enough juice left in the battery to crank the engine. Ended up having to take SWMBO's car instead, and boy did I feel a plonker!! Shocked
Post #294038 18th Nov 2014 9:55pm
Discotigger
The T91 remote has two buttons, the left button switches the heating/ventilation 'ON' the right button swiches it 'OFF'
There is also the following with my T91 fob:-
If the temp is low enough and you press the 'ON' button the light on the fob glows red to show the FBH and fan has started. If the temp is high enough and you press the 'ON' button then the fob light will turn green and only the fans will start to cool the interior.
Not sure at what exact temp these two functions operate at though.
Post #294040 18th Nov 2014 10:05pm
JPS
Ok thanks that makes it a bit clearer. When pressing the on button I'm only getting a green light the system comes on but is just the fans with no heat. I'll give it another try in the morning incase it isn't cold enough.
Post #294045 18th Nov 2014 10:19pm
Discotigger
^ Thumbs Up
Let us know how you get on.
Post #294046 18th Nov 2014 10:23pm
JPS
Well it seems it's all working great. I switched the system on about 20min ago to test it (thought it was just the fans) went outside just heard a clicking from the back of the car and opened her up and was lovely and warm inside. Actually sat it there for a few minutes as was warmer than in the house Laughing
Post #294048 18th Nov 2014 10:31pm
Discotigger
Good to hear, you're cooking on doozel now!! Thumbs Up
Post #294049 18th Nov 2014 10:33pm
Yep that's working then👍
Clicking is the fuel pump, if you can hear that all is well! There is nothing that can't be fixed with a hammer😜😜
Post #294051 18th Nov 2014 10:43pm
JPS
Thanks guys will deffinatley come in handy this winter. Have just fitted a new bosch battery also so hopefully that will help Thumbs Up
Post #294099 19th Nov 2014 9:00am
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Grrrrrr!
Mine is only showing green and no ticking from the pump , blows cold air for 2 mins then switches off Big Cry Big Cry
Post #294210 19th Nov 2014 8:06pm
