![]() | Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Thanks for the info Pete, what did you use to coat the final fibre glass shiny black? Howard
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8709 ![]() ![]() ![]() |
This is gloss black paint, well prepared beforehand to be as smooth as possible
Thanks - it looked so smooth I thought it was like a silicon finish - well done Howard
Well it's only taken three months but I have finally found a MemoryMap.apk file that actually works with the Android head unit, for some reason when I tried to download it from the google play store it kept saying I didn't have a compatible device, even though I had downloaded lots of other apps OK... it just didn't seem to like MemoryMap, looked around for the file to load it from the SD card and found a fare few but they all crashed or didn't load.... had a look last night and found a new one and..... it works.... loaded an old overlay and can see it, it knows where I am and moves when I do.... |
It is really useful to know this thermostat solution exists - well done for finding and highlighting it.
They put a 110deg stat to reduce emissions at part throttle openings, it will have minimal, if at all, effect on the way they measure them for an MOT....
My gut feeling is that 108c is fine when engine is new but would rather it is cooler 90000miles later for reasons you mentioned.
It's certainly not as hot as it was.... thank god, it was ridiculously hot before, thought it was going to melt the vents...
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 ![]() ![]() ![]() |
Hiya,
Just using a mag mount at the moment, don't use it much.... Pete
Thanks, think I'll be going with that too as I can't find any neat and tidy brackets / solutions.
Couple more jobs done recently, one of the rear lower hub rose joints started squeaking like mad, it was starting to scare children and old ladies....
Kaj Member Since: 28 Oct 2014 Location: Jeddah Posts: 4 ![]() ![]() |
Excellent work Pete |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
Would you make one of those fibre glass boxes for the snorkel for us if we asked nicely? =o
