![]() | Home > Technical (L322) > Rear Fog Lights |
I would suspect switch. Is one of the fog light buttons loose? This happened on mine as the rear fog light almost felt it was going to fall off. I bought a new switch but flogged car before fitting. Mine was intermittent. Present :2008 TDV8 HSE
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
switch feels fine in its mounting.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35772 ![]() ![]() |
water in the light unit?
LCM? Cheers
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 ![]() ![]() ![]() |
Light Control Module, the switches talk to it, it talks to the bcm can linked ect ect ect If everything is under control you are not going fast enough.
cheers, will do some more digging about Cheers
it turns out to be the tow pack (after market fitted) disconnect the loom to the hitch connector and fog lights work as they should.
