Home > Technical (L322) > Rear Fog Lights
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Rear Fog Lights
10MY 3.6tdv8
i have intermittent rear fog lights.
according to the handbook they are only meant to come on if the front fog lights are on (ign on and lights on too)
they sometimes come on regardless of the front fogs being on or off. (ign and lights on)
sometimes they dont come on at all (when the button is pushed) ign, & lights on
the indicator lamp on the dash for the rear fogs always comes on when the button is pushed regardless of whether or not the lights are actually on
i am guessing the switch may be at fault? or a bad connection somewhere.
is this a common fault or one people have come across before? Cheers
James
Post #294054 18th Nov 2014 11:06pm
Googsy
I would suspect switch. Is one of the fog light buttons loose? This happened on mine as the rear fog light almost felt it was going to fall off. I bought a new switch but flogged car before fitting. Mine was intermittent. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #294072 19th Nov 2014 1:00am
JST
switch feels fine in its mounting.
anyone else experienced it? Cheers
James
Post #294090 19th Nov 2014 7:25am
water in the light unit?
otherwise connections or lcm maybe...
a diagnostic tool like the GAP iidtool should show the errors.. ... - .- -.
Post #294092 19th Nov 2014 7:33am
JST
LCM? Cheers
James
Post #294245 19th Nov 2014 10:39pm
noworries4x4
Light Control Module, the switches talk to it, it talks to the bcm can linked ect ect ect If everything is under control you are not going fast enough.
MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
MY 12 Full Fat 4.4 TDV8
1952 Series 1 80" 3ltr 6cyl
Post #294246 19th Nov 2014 10:42pm
JST
cheers, will do some more digging about Cheers
James
Post #294299 20th Nov 2014 9:33am
JST
it turns out to be the tow pack (after market fitted) disconnect the loom to the hitch connector and fog lights work as they should.
checking with autologic the fitters also neglected to tell the vehicle it had the tow electrics fitted.
i believe there is a fault with the fitting of the loom so will do some checking into it.
had not towed with it yet, so hadn't checked they worked! Cheers
James
Post #296587 2nd Dec 2014 7:54pm
