![]() | Home > Maintenance & Mods (L322) > TDV8 front calliper pin removal |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Wd40 and leave for 10 mins . Take the spring pressure off the pin bywedging a screwdriver in and tap it out GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
i use a similar diameter nail to knock the pin out. ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
They can be stubborn on the brembo type calipers, we had one completely stuck in on one hilux, a bit of wd40 should help but DO NOT get it on your discs, it will contaminate your new pads! There is nothing that can't be fixed with a hammer😜😜
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Having recently done mine. It's surprising how much you need to whack them to compress the clips that hold it in. As others have said try wiggling a screwdriver to shift the alignment.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Then a skim of copper grease before they go back in! Next time they will easily come out |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
An even bigger hammer! Previous cars:
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
I had this problem when trying to do the 4.4 TDV8 front pads. They are different to the earlier 3.6 tdv8. I ended taking it to the local Indy who had to get the torch on them to heat them enough to drift out.
Sorted Cliffc? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
cliffc Member Since: 30 Dec 2013 Location: lichfield Posts: 50 ![]() ![]() ![]() |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
Paging Dr. Miggit! another prototype for your shed maybe? |
Thought about just removing the caliper ?
Did the Californian pin removal tool work? Or bigger hammer... |
Just received the caliper pin removal tool from USA. Looks spot on. Will try it out at the weekend and post an update. |
