Home > Maintenance & Mods (L322) > TDV8 front calliper pin removal
cliffc
United Kingdom 2012 Range Rover Autobiography TDV8 Zermatt Silver
Had a go at replacing the front disc brake pads on my 2011 TDV8 this morning but was thwarted by one of the retaining pins which would not drift out as expected. Anyone have any good tips for removing calliper pins that are stuck and have corroded?
Post #296045 30th Nov 2014 12:19pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Wd40 and leave for 10 mins . Take the spring pressure off the pin bywedging a screwdriver in and tap it out GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #296052 30th Nov 2014 12:39pm
i use a similar diameter nail to knock the pin out. ... - .- -.
Post #296054 30th Nov 2014 12:45pm
They can be stubborn on the brembo type calipers, we had one completely stuck in on one hilux, a bit of wd40 should help but DO NOT get it on your discs, it will contaminate your new pads! There is nothing that can't be fixed with a hammer😜😜
Post #296093 30th Nov 2014 3:56pm
sako243
Having recently done mine. It's surprising how much you need to whack them to compress the clips that hold it in. As others have said try wiggling a screwdriver to shift the alignment.
Basically you need to break the seal that's formed from from the oxidisation process.
Post #296159 30th Nov 2014 9:25pm
Then a skim of copper grease before they go back in! Next time they will easily come out Thumbs Up
Post #296210 1st Dec 2014 12:37am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
An even bigger hammer! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #296253 1st Dec 2014 10:45am
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
I had this problem when trying to do the 4.4 TDV8 front pads. They are different to the earlier 3.6 tdv8. I ended taking it to the local Indy who had to get the torch on them to heat them enough to drift out.
Thumbs Up well done at getting one of them out!
Post #296413 1st Dec 2014 8:43pm
paulmoran2
Sorted Cliffc? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #296543 2nd Dec 2014 12:46pm
cliffc
Thanks for all the replies and helpful suggestions. Looking over other model forums the latest Brembo pins are proving difficult to remove for other car models too.
I've soaked the pins in penetrating fluid and will have another attempt early next week. One of my difficulties was the drift slipping on the pointed head of the pin. I've ordered one of these specialist Brembo drifts from California(picture in my album). Hopefully it will help me shift the stubborn pin. Will let forum members know how it performs.
http://www.racingbrake.com/product-p/ccp01.htm
Post #296572 2nd Dec 2014 4:37pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Paging Dr. Miggit! another prototype for your shed maybe? Laughing
Post #296574 2nd Dec 2014 5:13pm
paulmoran2
Thought about just removing the caliper ?
It's only a couple of bolts , but you'll need to soak in WD40 and use a breaker bar to loosen them , but once it's off you can gain easier access to the pins
Like the specialist machined tool tho Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #296577 2nd Dec 2014 6:15pm
stenh02
Off Topic
Aye, Dr Miggit could do a wheel guide-o-matic and calliper bolt pin remover in one piece of kit!
Post #296583 2nd Dec 2014 7:32pm
stenh02
Did the Californian pin removal tool work? Or bigger hammer...
Post #297989 9th Dec 2014 9:24pm
cliffc
Just received the caliper pin removal tool from USA. Looks spot on. Will try it out at the weekend and post an update.
Post #298234 10th Dec 2014 9:06pm
