Home > Technical (L322) > Routine operation of the transfer 'box
How often do you operate the transfer box of your offroad vehicle?
Weekly when I check oil and tyre pressures etc
25%
 25%  [6]
Monthly as per LR recommendation
37%
 37%  [9]
Annually if I remember
37%
 37%  [9]
Errrrrr, what's the transfer box, I will never take it off road so I'm not bothered if the next owner has to fix it
0%
 0%  [0]
Total Votes: 24
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I have often asked folks with Land Rovers fitted with a dual-range gearbox how often they operate the system for the transfer from High to Low ranges. More often than not the reply is a blank look and after a few seconds they either say "never" or "what's the transfer box". I have always been advised to operate the transfer box at least monthly, but it does no harm to work it more frequently. Not operating it frequently can lead to very expensive repairs if you ever do need to engage low box for example in deep snow. It is very easy to operate even on your drive or the street in front of your house - start the engine, select neutral on the shifter, press or flick the transfer switch and you should hear a little electric motor engaging (it's quite quiet) and the dash light should come on and hopefully you now have low ratio engaged when the light on the dash becomes steady. It is important, even if you never take, or intend to take, the car offroading that you do operate the transfer box to prevent seizure of the transfer motor and to get some lubrication to the mechanism. As modern Land Rovers use a viscous coupling instead of a mechanical difflock you can drive a short (100m or so) in low box on a hard surface without fear of the dreaded transmission wind-up, if you do want to drive further then do it on a slightly slippery surface like a gravel road or even dry grass. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #29658 28th Sep 2010 9:50am
when i had my navara d40 , i was told to use it once a month as well. ... - .- -.
Post #29659 28th Sep 2010 9:56am
Fox
I use mine every couple of days in traffic, to make sure it's all working properly. Including manual selection of gears in low range.
Post #29660 28th Sep 2010 9:59am
Vogue
When used off road or tow a heavy trailer, usually 3 or 4 times a week - especially in the winter
Post #29668 28th Sep 2010 10:44am
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
The 07 MY onwards cycles the box on every start...according to the technician that attended my car the other day...this is to counter this very problem.
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #29670 28th Sep 2010 11:31am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
A friends Range Rover classic was siezed in high, through lack of use. Would not budge!
Post #29673 28th Sep 2010 12:10pm
M44K TS
Every couple of weeks I put mine in low range just to check it works. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #29731 28th Sep 2010 3:49pm
Vogue
bit shocked at the poll results, do 37% of us actually check our oil and tyre pressures every week??
for me its once a month if I remember Shocked Embarassed
Post #29732 28th Sep 2010 4:04pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
You can drive as far as you want at up to 65mph in low box, it has no bearing on the centre diff operation..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #29734 28th Sep 2010 4:29pm
davemfox
What he said
Dave 1993 YZF 750 SP
Post #29744 28th Sep 2010 5:44pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
mmmm when i get board and siting in the car i start to play with buttons and knobs and usualy the hill desent and low ration come to play.
that s why my outside temp gauge now does not read in deg c it does deg f Big Cry and its a trip to the dealers to put back you no what they say idle hands makes for a trip to the dealers Twisted Evil Embarassed Censored 02 Range Rover HSE Zambezie silver 4.4
Post #29746 28th Sep 2010 5:53pm
cookie42
2005 Range Rover Vogue Td6 Java Black
never use it , mainly because the bloody thing didnt work when i bought the car
Post #29747 28th Sep 2010 6:54pm
I check it every week, in the hope it will start working properly. I can switch to low ratio, but it won't switch back up to high. Have to turn off ignition, start up again and fiddle with the switch, then maybe repeat to get back to high. Someday.... Confused
So can we please have chapter and verse on driving in low ratio. Tim and Thrasher seem to differ in opinion? .
Post #29775 28th Sep 2010 10:20pm
DMRR
Low ratio is just what it implies, in standard drive, ie no terrain response picked, just likely any Land Rover since the Range Rover classic and the Stage One V8 with permanent four wheel drive - low box is just lower gearing. In the series vehicles prior to the Stage One and early 110's there was a lever to operate low box, which locked the centre diff, making sure you had to drive off road. Discovery had a manual centre diff etc, but all modern can speed in low box as it is not related to the centre diff operation. Modern lesser crap locks the centre diff....(read not LR) Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #29779 28th Sep 2010 10:53pm
Tim in Scotland
In modern Land Rovers there isn't any manual difflock at all, the job that it used to do is now done by the viscous coupling which detects slippage and the fluid becomes more viscous between the plates in the coupling and in effect become solid. Even if you are fortunate to have an e-diff on the rear axle (standard on S/C 5ltr IIRC) you cannot manually control it, it also automatically engages. I was most impressed to see how well an RRS with the optional e-diff performed last weekend offroading in the Argyll Forest, and made a Dakar Challenge Mitsubishi Evolution look stupid when it came to traction in slippery conditions as the Evo has to have 5-6 wheel rotations to detect that it needed it's auto hubs to lock up, the LR system detected slip[page instantly and engaged the e-diff far quicker. One advantage of the system currently installed in all modern Land and Range Rovers EXCEPT Defender (which still has the manual diff lock referred to by Thrasher) and also X series BMWs, is that the viscous coupling cannot permit transmission wind up whereas in Defender driving on dry, metalled roads with the diff lock engaged in either high or low ratio you will do severe damage to the transmission due to wind up. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #29781 28th Sep 2010 11:16pm
