Home > Wheels & Tyres > Cooper Zeon LTZ Dilema
Page 5 of 7 <1234567>
miggit
I had a set of Kuhmo KL71's on a Landcruiser, and while I found then to be very capable off road, on road was a different matter, firstly they are very loud, and they scare the Censored out of you in the wet Shocked Shocked
The Coopers all be it still noisy, behave very well in the wet Thumbs Up
Oh and was the TJ a 2.5 or 4 ltr? Spooky that its the same color Very Happy And even more spooky its parked outside Christ Church on the common! Thought that I recognised the back ground! Yesterday I couldn't spell Engineer... Today I are one!
Post #293193 15th Nov 2014 4:20pm
It was a 4.0 and much fun! Yes its Christchurch Chorleywood just up the road from me where my kids went to school. The TJ was bog standard when I bought it and I enjoyed the modification.
Same colour as the D3 or something else?
Post #293265 15th Nov 2014 9:06pm
noworries4x4
Hope I have done the right thing I have just taken the plunge and purchased these on here.
http://www.fullfatrr.com/forum/post296142.html#296142 If everything is under control you are not going fast enough.
MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
MY 12 Full Fat 4.4 TDV8
1952 Series 1 80" 3ltr 6cyl
Post #296143 30th Nov 2014 8:38pm
miggit
So your going to be 3.5 mm nearer the ground and you'll accelerate a fraction quicker, oh and you'll be going fractionally slower than the displayed speed, big deal!
If your that worried about it, find someone with a sat nav (after sales) that displays the current speed, they are very accurate, whizz the car up the road, I surgest that you employ the cruise control, and check the speedo against the sat nav. My FFRR does 69 MPH when the speedo reads 70 MPH, thats with std tyres. Yours will probably do 68 MPH when it says 70 MPH.
My Jeeps well out, reads 25 MPH when it's doing 30 MPH Shocked That will teach me to play around with wheel sizes Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #296153 30th Nov 2014 9:12pm
noworries4x4
I am already rolling on 275 45 20s so no difference except for tread, Craig at Can Tech recons I have got a set of RRS wheels on as they are Stormers with directional grabber road tyres, they hold the road well.
So a set for Winter and a set for summer all is good.
Post #296236 1st Dec 2014 8:35am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Cooper LTZ are not winter tyres. Chunky tread does not make a winter tyre - it's probably counterproductive in every winter situation but deep fresh snow.
Post #296263 1st Dec 2014 11:38am
Luxury4Paul
United States 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Mine work fine in rain, dirt, sand, mud, water, snow, sleet. You name it. Love them.
Post #296980 4th Dec 2014 3:36pm
Philip
Maybe, but they aren't winter tyres and aren't sold as such - not a winter compound, not a winter tread pattern. Coooper make winter tyres but the LTZ isn't one of them.
Post #296990 4th Dec 2014 4:35pm
unusually i find myself agreeing with trommel, the ltz is an all terrain tyre and not a mud and snow one,
http://www.coopertire.co.uk/tyres/high-per...r-zeon-ltz ... - .- -.
Post #296991 4th Dec 2014 4:57pm
miggit
I'm not trying to put a fly in the ointment, but aren't the LTZ marked up as M+S? I always took that to mean mud and snow, and while I will accept that they are not full blown winter tyres, surely they are alright for the white stuff.
The only thing that I've come across that tripps up a M+S tyre is ice, and as far as I'm aware the only thing that will cope with that is studded winter tyres, and Kevlar underpants Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #296999 4th Dec 2014 5:40pm
they might be marked M+S but that could stand for mud + sand...
cooper do do a specific mud and snow tyre in their range.. ... - .- -.
Post #297001 4th Dec 2014 5:47pm
Philip
In itself, the M+S marking means nothing - it's neither measured nor defined in the EU; in the US it just refers to geometry of the tread pattern (in effect meaning most tyres can carry it). For example, the 20" M+S-marked Eagle F1s the L405 comes on are exactly the same as the ones which don't have the marking as far as I can tell.
Post #297013 4th Dec 2014 6:42pm
miggit
So M+S isn't worth the rubber it's printed on Smile
And I know that Cooper do Mud tyres in their range, I've got them on my Jeep!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Yesterday I couldn't spell Engineer... Today I are one!
Post #297022 4th Dec 2014 7:33pm
One of the markings on the sidewall of a tire is a Uniform Tire Quality Grading or UTQG grade.
The tire's UTQG rating provides information on three aspects of the tires durability and operational characteristics.
They are:
tread wear,
traction
and temperature.
The tread wear number comes from testing the tire in controlled conditions. The higher the number, the longer the life expectancy of the tread.
Since no one vehicle will be subjected to exactly the same surfaces and at the same speeds as the controlled conditions, the number can only be an indicator of expected tread life in 'normal conditions'.
The rating is based on a percentage of the projected wear life. For instance, a tire rated at 400 has a projected life twice that of a tire rated at 200.
There are many factors that influence wear, such as vehicle speed, road surface, climate, vehicle wheel alignment, and the driving characteristics of the driver. As such the rating can only be an indication of the anticipated wear characteristics of the tire in controlled conditions.
A traction rating is a letter based indicator system. The rating is based on the tire's ability to stop a vehicle on wet concrete and asphalt in a straight-line situation. It does not indicate the tire's cornering ability.
The Tire traction indicators are rated as AA, A, B or C. AA is the highest rating.
It is important to note that the test and relevant rating does not indicate hydroplaning resistance, dry or snow traction capacity, or cornering capability in wet, dry or snow conditions.
The Temperature rating of a tire is a letter based on a controlled step speed test. The possible ratings are A, B, and C. The rating is a measure of how well the tire dissipates heat and how well it handles the buildup of heat. Excessive heat buildup can reduce tire life, or even lead to tire failure. However, while temperature plays a role in the speed capability of a tire, it is not the only factor.
It is important to remember that these ratings are based on standardized test conditions, and the tests do not reflect tires that are operated in overloaded, under inflated, and/or misaligned conditions. It should also be noted that when rated one tire might be a low "A" and another a high "B", so the actual operating performance differences might be relatively small.
It is not uncommon for there to be differences in UTQG ratings within a given tire design. Sometimes a particular vehicle manufacturer will require certain properties for the tires supplied to their vehicles, which can affect the ratings, both positively and negatively.
Sometimes there are differences between small sizes and large sizes of tires in a given design. All of these aspects can affect the actual rating that is put on the sidewall.
So there we go , second best traction rating good wear rating dissipates heat reasonably well as for M+S Censored knows ,Marks & Sparks ? 2008 MY Supercharged
Post #297115 5th Dec 2014 3:51am
ebajema
Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #297117 5th Dec 2014 5:13am
