![]() | Home > Technical (L322) > Venture cam refurb Eneloop batteries |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Gents having used the fabulous write up on here to dismantle my venture cam which was suffering from battery failure I have replaced the batteries with Eneloop battery pack which is exactly the correct size and comes with tails so all you have to do is solder the connections on ten minute job. Plus the batteries discharge at only 10% in the first year if unused. The pack is a bit dearer but well worth it bought from Conrad Electronics |
Not a great pic but you can see the battery pack comes made up correct size bit of solder bit of tape or heat shrink job done and no cutting of cam casing |
dave.s Member Since: 01 Nov 2011 Location: Isle of Wight Posts: 127 ![]() ![]() ![]() |
Any chance of a link to exactly which ones you bought.
http://www.conrad-electronic.co.uk/ce/en/p...AREA_14717
Thanks for that have ordered some. probably never
