Home > Technical (L322) > Venture cam refurb Eneloop batteries
Sandyt
Gents having used the fabulous write up on here to dismantle my venture cam which was suffering from battery failure I have replaced the batteries with Eneloop battery pack which is exactly the correct size and comes with tails so all you have to do is solder the connections on ten minute job. Plus the batteries discharge at only 10% in the first year if unused. The pack is a bit dearer but well worth it bought from Conrad Electronics Thumbs Up
Post #297212 5th Dec 2014 5:21pm
Sandyt
Post #297213 5th Dec 2014 5:27pm
Sandyt
Not a great pic but you can see the battery pack comes made up correct size bit of solder bit of tape or heat shrink job done and no cutting of cam casing
Post #297214 5th Dec 2014 5:28pm
dave.s
Any chance of a link to exactly which ones you bought.
cheers, dave.
Post #297215 5th Dec 2014 5:33pm
Sandyt
http://www.conrad-electronic.co.uk/ce/en/p...AREA_14717
This should be it it was 18.49 because of the Eneloop
Post #297216 5th Dec 2014 5:37pm
dave.s
Thanks for that have ordered some. probably never
use it but if its there it has to work.
dave.
Post #297218 5th Dec 2014 5:53pm
