Home > Technical (L322) > LCM info needed please
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
I have intermitten messages that various lights are out and noo the indicators have decided to flash at double the speed.
Having been advised that it could be the LCM and that any replacement has to be reprogrammed by the main stealers.
If that is the case then how muchy approx to re-program
Any info would be good please folks.
cheers in advance
Bill Made in Scotland frae 'Girders'
Post #297618 8th Dec 2014 4:44am
The system seems to be over sensitive and at this time of year when the moisture starts getting to everything they seem to get upset, try removing and cleaning all the bulbs and holders, if the glass on any of the bulbs is starting to darken, then change them, just make sure everything is clean and new looking, the system is so sensitive it can pick up when a bulb is going to blow but hasn't yet...
If you have an IID tool or similar and can get into the CCF file you can turn off the cold monitoring on most of the lights, it won't let you turn it off on the sidelights though... Pete
Post #297642 8th Dec 2014 10:02am
Try a hard battery reset first... Although, early LCM's are getting problematic with age!
Worth a try first Thumbs Up
Post #297645 8th Dec 2014 10:29am
Bofa Bill
Thanks Guys.
Hard Battery reset>?
disconnect earth and leave it 30 mins?
Pete....
IID thingys, is that one of the thingys from contact on here....... jings ive forgotten his name
I bought both the supensions reset and the more exspensive PC thingy.
I was thinking of selling that gizmo as I have never used it and nor do I know how to use it so flog it. Made in Scotland frae 'Girders'
Post #297847 9th Dec 2014 6:09am
steptoe
Re: LCM info needed please
Unnecessary quote removed
you can fit a used lcm from another range rover without any reprogramming.
you'll have a small "dot" next to the mileometer which shows something has been changed but everything will work as normal.
Post #297976 9th Dec 2014 7:25pm
Bofa Bill
Thank you Stetoe, that is good news. Made in Scotland frae 'Girders'
Post #298039 10th Dec 2014 2:22am
Granted... Yes they are usable second hand...
BUT!!!
Will ONLY work correctly if that RR is from the exact model, year & marketplace as yours! They are programmed to the VIN of your car so second hand ones will almost certainly bring up strange faults sir...
Post #298090 10th Dec 2014 10:53am
Bofa Bill
Thanks Craig.
Back to plan 'A' or is it 'B' or 'C'
Brrr its cauld ootside so I can live with it till the sun shines a wee bitty longer. Censored Made in Scotland frae 'Girders'
Post #298248 10th Dec 2014 10:35pm
fisha
Worth looking at the wiring diagram for the lcm side of things as some light circuits are mechanical relay operated, and others have MOSFET transistors to power circuits.
I had problems with my lcm and the interior lights being gubbed . . . . A result of disconnecting the light switch with the battery still connected one time.
I stripped the lcm apart and looking at the board could see the board scorched around the MOSFET that controlled the circuit. The MOSFET chip was labelled and I was able to source the same part online for a few quid each but never ordered some because I I ended up selling it as a trade in. The chip was soldered quite well to the board, but I genuinely believe that I would have been able to replace it with careful use of a soldering iron.
I.e. I'm of the opinion the lcm is within the realm of diy repair for those that really want to. V8 or else ...
Post #303090 6th Jan 2015 1:14pm
