![]() | Home > Maintenance & Mods (L322) > side steps removal |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
if you take off the steps [easy] then you'll be left with front flaps that have a 'cut out' in them where the end of the step went in...you can take these front flaps off but you'll have screw holes left and probably a dis-colouration line showing...you can replace the 'step' flaps with normal ones.. ... - .- -.
| crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102
Ok, thanks Stan, so if I take them off and ordera set of regular (non side-step flaps) then they will attach in the same screw holes as the removed flaps I hope.
you might find that the replacement flaps wont marry up on the holes...if you look at the powerfuluk video on the fitting of steps/flaps you'll see that the step/flaps have different holes to the normal flaps .....but it shouldnt matter as they will be hidden.. ... - .- -.
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
If you do want to go flapless the small plastic panel with the screw holes is cheap to replace. |
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
The back bumper isn't though - and when you factor in the cost of paint its not cheap - the flaps and side runners look good IMHO - plus make it easier for youngsters and the mature passengers to get in |
Rear flaps are normally attached inside the wheel arch no painted panel damage.
If fitted correctly by main dealers/professionally, rear flaps should have the same M8 nut & bolt through the side of the flap setup as the fronts... Meaning, when removed you should have (if fitted properly) a hole left in the side of the rear bumper sir... |
I guessed you would be along... |
@ Craig - quite correct |
Thanks for all the feedback there. I am still undecided about if I will remove them yet. With three youngsters, I haven't conducted a poll on their vote (with/without runners) and I am easy either way.
Your welcome sir |
| All times are GMT |
