Home > Maintenance & Mods (L322) > side steps removal
crispy2
Australia 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
side steps removal
Hi there, my '07 S/C has the factory side steps which are moulded into the back side of the front mudflaps.
If I wanted to remove the side steps is there a regular front mud flap I should fit and is the removal of the old steps and mud flaps an easy operation?
The opinion on here about these seems slightly swayed towards the Ffrr is nicer looking without side steps.
Any comments please about how easy this mod might be appreciated.
The off roading benefit with additional clearance provides additional motivation to want to do this too.
Pete. '07 4.2 S/C
'13 X3M
Post #297880 9th Dec 2014 11:09am
if you take off the steps [easy] then you'll be left with front flaps that have a 'cut out' in them where the end of the step went in...you can take these front flaps off but you'll have screw holes left and probably a dis-colouration line showing...you can replace the 'step' flaps with normal ones.. ... - .- -.
Post #297899 9th Dec 2014 1:28pm
crispy2
Ok, thanks Stan, so if I take them off and ordera set of regular (non side-step flaps) then they will attach in the same screw holes as the removed flaps I hope.
Regards
PC Thumbs Up '07 4.2 S/C
'13 X3M
Post #297914 9th Dec 2014 2:55pm
you might find that the replacement flaps wont marry up on the holes...if you look at the powerfuluk video on the fitting of steps/flaps you'll see that the step/flaps have different holes to the normal flaps .....but it shouldnt matter as they will be hidden.. ... - .- -.
Post #297917 9th Dec 2014 3:08pm
If you do want to go flapless the small plastic panel with the screw holes is cheap to replace. Thumbs Up
Post #297942 9th Dec 2014 4:47pm
Vogue
The back bumper isn't though - and when you factor in the cost of paint its not cheap - the flaps and side runners look good IMHO - plus make it easier for youngsters and the mature passengers to get in Thumbs Up
Ignore Gary - he just doesn't do flappy bits Wink Laughing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #298004 9th Dec 2014 11:07pm
Rear flaps are normally attached inside the wheel arch no painted panel damage.
He asked a question he got an answer. I remove them without damage regularly. Surprised
Post #298011 9th Dec 2014 11:35pm
If fitted correctly by main dealers/professionally, rear flaps should have the same M8 nut & bolt through the side of the flap setup as the fronts... Meaning, when removed you should have (if fitted properly) a hole left in the side of the rear bumper sir... Thumbs Up
Post #298021 10th Dec 2014 12:09am
I guessed you would be along... Laughing
Post #298023 10th Dec 2014 12:17am
Vogue
@ Craig - quite correct Thumbs Up
@ Gaz - Knew you would bite Laughing Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #298024 10th Dec 2014 12:21am
crispy2
Thanks for all the feedback there. I am still undecided about if I will remove them yet. With three youngsters, I haven't conducted a poll on their vote (with/without runners) and I am easy either way.
Thanks, I now have the info to proceed if I reach that point.
 '07 4.2 S/C
'13 X3M
Post #298025 10th Dec 2014 12:25am
Your welcome sir Thumbs Up
Post #298030 10th Dec 2014 12:34am
