![]() | Home > In Car Electronics (L322) > Newbie with a couple of question (RR2002 Vogue) |
BenjaminD Member Since: 08 Dec 2014 Location: Brisbane Posts: 19 ![]() ![]() ![]() |
Just saw that pin 1, 4, 5, 8 and 11 was not connected on the original loom.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7948 ![]() ![]() ![]() |
Can you not disconnect the pin for ibus and move it ?
I'm not sure how I could disconnect and move the physical pin since it's coming out of the old radio and no wire can be seen towards that pin. |
Update:
The iBus will need to be connected to both old and new units to get all features to work, so if the magic box on the new unit should work it, then pin 9 can stay on the old radio as normal.
Have no idea how I could connect the two. Can I tap that off the existing PIN9? I feel this sort of thing is getting a bit ahead of me. The CAN BUS on the new loom only works when PIN 9 is into the new loom. If PIN 9 goes into the old one as I did today it doesn't work.
I haven't tried any of the sources method yet.
I'm not sure I'm following what you're trying to say. According to Ironhorse's explanation and pictures, he didn't connect anything to the bm54. As far as I can understand it, he unplugged the loom out of bm54, into the new unit. Disconnected and reconnected the big connector on the crossover box (big black thing at far left when looking at installation ((DSP?)) I apologise if this is bad forum-etiquette but it's the only place I could find his picture. Kind of difficult to see if anythings plugged in the bm54. http://www.rangerovers.net/forum/6-range-r...creen.html The only difference I can see is that he has the 2x12pin connectors in his new loom, but I don't.
Do you mean taking out pin 2, 3, 6 and 7 out of the 16pin loom and replacing them with the speaker-feeds of my new loom? Again, sorry for all the stupid questions and thanks for your follow up. I do appreciate it!!! |
He seems to have an additional fakra fully populated(40 pin) ISO parrot adapter, that I don't have. It's in his post (not in pic) but he didn't mention it via email. That's probably whats going to his bm54 and what confused me. |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
do not take this the wrong way but:
So it looks like that is using the telephone interrupt if it's a loom for a phone kit.
thank you
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi BenjaminD, I've been looking at the pictures that you've given and I think you will have a problem if you try to use the new loom with out modifications. Firstly on page 2 you ask what the white plug is for, it would appear that it goes to the BMW canbus module and the cable marked ill+ is the dimmer wire that needs to be connected to a + light wire. If you are trying to keep the DSP then I'll assume that you've moved the old sat nav display in to the glove box. So you'll need to connect the new sound to the feed that comes out of the BM54 but leave all the other wires connected.
PS all the Ibus leads are joined together in the fuse box, so doubling up should not be an issue |
you do not have to cut any speaker wires
