![]() | Home > Technical (L322) > RED flashing alarm light |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I don't remember every seeing a red flashing LED there, only on the dash (of the MY 2006 NAS 4.2). Maybe it is just my memory since I haven't seen the car for about 1 year now. MY 2010 5.0 SC Galway green and sand interior!!
| mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425
Daft as it sounds - I cannot remember exactly where either - it's just I cannot see one flashing in the window of the vehicle when I look up my drive like I could before ! I haven't used the car for 4 months and noticed it yesterday. The battery is fine it has a Cetek 10 charger on it and was started last week a run for half-an-hour with no problems. Anyway , car going for rear brake pipes replacing today and MOT so will have a closer look on it's return |
Try a battery reset sir? Check the doors are closed correctly, do the indicators flash when you lock it? I think that signifies an alarmed/happy FF... If the indicators don't flash, not a happy car...
Eugene, they left the rear view mirror with the 2005 facelift sir |
Update - drove the car to the garage for the MOT and work to be done (front anti-roll bar linkages and rear brake pipe replacement) , and upon arrival locked the car and the red LED is now working again ? On the down side failed MOT for OSR brake pads less than 1.5mm (only been on for 4-500 miles) due to a seized brake calliper - more expense |
It's best practice to the rear callipers as a pair my friend... Just incase you were un-aware sir... |
Thank's for that advice. Was not really aware the TD6's suffered from calliper failures like the later supercharged and TDV8 ones do. Still in the hands of the garage as of Saturday morning as I have been on nights at work |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8791
Rear callers pretty much a consumable on ffrr. |
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836
Mine is a 2007 so led in dash near the steering wheel BUT when my drivers door handle cable snapped the car would lock from the remote, but not the drivers door, which I had to lock manually, and the led would not flash (which I understand means she wasn't superlocked or alarmed)
Update as to rear callipers - The garage had another look whilst changing the brake pipes and lo and behold - it was an error on their part - no sticking calliper and no worn brake pads ! WTF as they listed it as an MOT failure point |
| All times are GMT |
