![]() | Home > Technical (L322) > 4.4L TDV8 ZF 8HP70 flush : special technique? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
RRphil knows loads about auto boxes , hopefully he will pick up on your post.. ... - .- -.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
I’ll be looking to buy a 2012 L322 in the summer (Westminster or Autobiography) so I need to do some swotting up on the 8HP70 before them. If I can find a used transmission cheap enough I’ll maybe buy one off eBay and get it to pieces.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Über than you Phil ! |
EDIT :
Maybe I should see if I can source the Petronas Tutela cheaply here and start exporting it to the UK !!! I will now leave my gearbox filter/fluid change till I have it here or ship some Tutela to UK before it ships to another location |
Great post, as ever Phil. |
Ahh yes, of course, Petronas are a Malaysian company ![]() This is a copy of the same section from ZF’s TE-ML_11 specification from exactly a year ago (January 2014) and, as you can see, there’s no mention of the Tutela AS8 fluid.
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Eugene, Just for the avoidance of doubt, the ZF 6HP28X transmission fitted in your 5.0 SC Range Rover uses Lifeguard Fluid 6 (Shell M1375.4) and it's only the 6HP28AF versions, with the integral 4WD for Audi and Bentley, which use Lifeguard Fluid 8. Phil |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 460 ![]() ![]() ![]() |
I am just thinking about this oil and filter change for the 8 speed box myself, have asked Dan for the parts prices.
Hi, did mine (on the 4.4L TDV8) at 115.000 Km, did not feel any difference but the oil was obviously used and dirty.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
I've just been quoted £199.00 plus vat for the Britpart kit DA6106 which sounds quite reasonable to me given the fluid prices mentioned above.
Hi
Thanks for that. Is the pan a filter too? 405 AB exec seats Baltic and Cirrus
oui |
