![]() | Home > Maintenance & Mods (L322) > 4 wheel alignment oddity |
| Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261
Yep, seconded for the Hunter system |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
How do I get it into tight tolerance mode? Discovery 4 HSE
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
IID tool, Faultmate etc will do it. Failing that get your dealer to do it, take it for alignment and then back to the dealer to put it back to normal mode.
OK< so I rang around, Formula 1 centres use the Hunter Supertrak system, but they don't put the car into "tight tolerance mode", only the dealer will do that, so I rang them and they want £120 to do it. I am NOT paying that much. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
i had mine done at imperial tyres in swindon on a hunter setup and they didnt put it into tight tolerence mode.. ... - .- -.
Thanks Stan, it's not rocket science is it? |
might be for me but not for the chaps that done the alignment |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
I understand tight tolerence isnt required for L322 only for Disco3 and 4.Although if in any doubt it can do no harm. Present :2008 TDV8 HSE
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Not done when aligning mine either .
Well I couldn't stand it any longer, not even a day!
Great news I even left the Jaguar forum to sign in to see how you got on. Glad you got it sorted Adam |
Thanks Conor!
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Well done it is one of my major bug bears so know how you felt - good result
| All times are GMT |
