![]() | Home > General > Do you drop the suspension when parked overnight? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Are but you've got a much newer one than my BMW tractor! My pals P38 shoots up quickly too, think that mines just lazy, like the performance |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8712 ![]() ![]() ![]() |
Even with everything working spot on the earlier ones take much longer than the later ones to raise and lower....
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 ![]() ![]() ![]() |
You've got a point... ![]() JJ |
As with anything else the more you use it the quicker it wears out..... |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
or ... the less it is used, the more likely it is to have a problem when it is |
I guess its just another personal preference |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I use the button on the drivers door and do it as I am going into a parking space. I do it every time I use the car. My wife never does and probably slides off the seat and out the car Alex
![]() ![]() ![]() So what are you trying to do? Bunny hop over obsticales ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 ![]() ![]() ![]() |
Mine is always lowered to Access height when I get out, otherwise I can't get back in very easily, being a shortie and not having side steps. |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Have to lower mine to the bump stops (via IID) to get my mum in! Previous cars:
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
Interesting thread, but my question is , will you accelerate the wear on the bellows?
Handle it no problem at all, they spend all their time going up and down a bit when you drive... when they fail they split, they don't wear through so it is a failing in the material, not wearing them out....
ns2015 Member Since: 04 Jul 2016 Location: Berkshire Posts: 7 ![]() ![]() ![]() |
I always drop the suspension overnight using the drivers window switch panel. Usually works fine although it did lead to an air spring failing one morning! |
