![]() | Home > General > Do you drop the suspension when parked overnight? |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Are but you've got a much newer one than my BMW tractor! My pals P38 shoots up quickly too, think that mines just lazy, like the performance |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Even with everything working spot on the earlier ones take much longer than the later ones to raise and lower....
| Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420
You've got a point... JJ |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
As with anything else the more you use it the quicker it wears out..... |
| scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240
or ... the less it is used, the more likely it is to have a problem when it is |
I guess its just another personal preference |
| zarnd Member Since: 22 May 2014 Location: Kent Posts: 459
I use the button on the drivers door and do it as I am going into a parking space. I do it every time I use the car. My wife never does and probably slides off the seat and out the car Alex
So what are you trying to do? Bunny hop over obsticales Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
| Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212
Mine is always lowered to Access height when I get out, otherwise I can't get back in very easily, being a shortie and not having side steps. |
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424
Have to lower mine to the bump stops (via IID) to get my mum in! Previous cars:
| frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56
Interesting thread, but my question is , will you accelerate the wear on the bellows?
Handle it no problem at all, they spend all their time going up and down a bit when you drive... when they fail they split, they don't wear through so it is a failing in the material, not wearing them out....
| ns2015 Member Since: 04 Jul 2016 Location: Berkshire Posts: 7
I always drop the suspension overnight using the drivers window switch panel. Usually works fine although it did lead to an air spring failing one morning! |
| All times are GMT |
