![]() | Home > Maintenance & Mods (L322) > Front fog lights hazed up |
usually if you leave them on for a while the condensation should disappear. I opened mine up previously and cleaned the inside but condensation returned. I think its typical of this time of year with the variance in temperatures. Present :2008 TDV8 HSE
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Led start at £20 a pair somewhere on the bay fettle them in 👍 _____________________________________________________
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
£20 for a pair of front fog lights that fit the RR? I am assuming you are talking just about the blubs and not the housing/lenses. |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
I stick mine in the oven at 40'c and check them every 10 mins. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
They get "stained" inside (like the windows in your car) so if you remove them they do prise apart and you can simply wipe the inside clean my friend... Will return over time but its probably taken many years for them to get as dirty as they are now ![]() |
And if they are anything like mine were, the silvering on the reflectors will also be in a state |
Nope there are a few complete lights for 20 to 30 a pair just get the right size and you can adjust or make the brackets fit easily enough then click the bumper shroud back on over the top hq_auto_lighting_uk has a lot of sizes _____________________________________________________
Thanks all for the replies. I am assuming removal and re-fitting is not straight forward? Removal of the whole bumper, engine and transmission |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
this is for the RRS but the FF is the same,
ok - thanks. That's a lot easier than I thought. I don't have those surrounds on my fog lights, in fact, I'll have to check whether they have any surrounds as my mind has gone blank now.
pull or use a plastic lever.. ... - .- -.
Thanks for this advice. I will probably try and remove over the weekend. Literally, pull off the surround, unscrew the lamp, unclip the connector from the back of the lamp, remove the lamp, prise apart and clean, put back? Sounds too simple |
