Home > Maintenance & Mods (L322) > Front fog lights hazed up
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Folks,
It seems my front fog lights are quite badly steamed/hazed-up. Any work around to resolve this or replace them? I am presuming this is a common problem as I have seen a number of Range Rovers around with similar appearance.
Post #303108 6th Jan 2015 3:27pm
Googsy
usually if you leave them on for a while the condensation should disappear. I opened mine up previously and cleaned the inside but condensation returned. I think its typical of this time of year with the variance in temperatures. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #303113 6th Jan 2015 3:38pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Led start at £20 a pair somewhere on the bay fettle them in 👍 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #303125 6th Jan 2015 4:12pm
scwilson
£20 for a pair of front fog lights that fit the RR? I am assuming you are talking just about the blubs and not the housing/lenses.
Post #303146 6th Jan 2015 6:28pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
I stick mine in the oven at 40'c and check them every 10 mins. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #303166 6th Jan 2015 7:51pm
Re: Front fog lights hazed up
scwilson wrote:
Folks,
They get "stained" inside (like the windows in your car) so if you remove them they do prise apart and you can simply wipe the inside clean my friend... Will return over time but its probably taken many years for them to get as dirty as they are now Thumbs Up
Post #303211 6th Jan 2015 10:52pm
And if they are anything like mine were, the silvering on the reflectors will also be in a state Big Cry .
Post #303247 7th Jan 2015 12:43am
Scottyav
Nope there are a few complete lights for 20 to 30 a pair just get the right size and you can adjust or make the brackets fit easily enough then click the bumper shroud back on over the top hq_auto_lighting_uk has a lot of sizes _____________________________________________________
Post #303255 7th Jan 2015 1:18am
scwilson
Thanks all for the replies. I am assuming removal and re-fitting is not straight forward? Removal of the whole bumper, engine and transmission Smile ?
Post #303419 7th Jan 2015 4:48pm
this is for the RRS but the FF is the same,
Post #303421 7th Jan 2015 4:55pm
scwilson
ok - thanks. That's a lot easier than I thought. I don't have those surrounds on my fog lights, in fact, I'll have to check whether they have any surrounds as my mind has gone blank now.
EDIT - I do have surrounds Smile I am assuming since I don't have a push fit bezel like on the RRS that the FF bezel just pulls out or levers out?
Post #303425 7th Jan 2015 5:33pm
pull or use a plastic lever.. ... - .- -.
Post #303434 7th Jan 2015 6:01pm
scwilson
Thanks for this advice. I will probably try and remove over the weekend. Literally, pull off the surround, unscrew the lamp, unclip the connector from the back of the lamp, remove the lamp, prise apart and clean, put back? Sounds too simple Razz
Post #311985 10th Feb 2015 5:09pm
