![]() | Home > Maintenance & Mods (L322) > Sticking caliper? Fix or replace? |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380
Dealer price per calliper is £345.50 each! Discovery 4 HSE
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Wonder how much a rebuild kit is from Brakes Int... Cant be more than £30 a side surely! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Yep, according to AF they are anyway. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top 1998 90 TUL FFR Hard Top XD Wolf 1993 90 Tdi *Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774
IS it different to the ones on the TDV8 then? or is it just a TRW like the rest...... If so they are available from most local motor factors, I got a refurbed trw one for mine from ECP and another from a local factors after the ECP one stuck on again...... the second was refurbed by brake engineering. Still about £60ish.
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
Are you sure it's not a badly adjusted handbrake after refitting the new discs and pads ? I'd be amazed if the calipers on your 5.0 Supercharged were fooked already.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
I've just spent an hour reading and searching old threads. Lost count of the numbers of people who have had the exact same symptoms, and all turned out to be callipers sticking.
When the other one went on the ff I have the heat was all the time. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
4.4 TDV8 & 5.0 use 6 pot Brembo's up front and a much larger rear calliper than was on the older 3.6 TDV8 or 4.2 |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Is it 6 pot caliper front, 4 pot caliper rear... For the 4.4TDV8 & 5.0? |
6 pot front, sliding rear.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
But is the piston at the rear bigger?
No they are still the same system Will, just bigger! Almost twice the disc/pad area of my old 3,6... |
So much for progress |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
If they were fine before the new pads were fitted, could that not be the problem? Could the pad be sticking in the calliper in some way? I've had pads rusting in to the slides they sit in, a quick filing and lubing does the trick, but you have new pads so maybe not. Previously..
