![]() | Home > In Car Electronics (L322) > CTEK and GAPiiD |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Don't know whether this is the right place. If not can you move it please, Stan?
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
You need a charger with a "supply" function - the manual for the MXS 7.0 will tell you if it has this (off the top of my head it doesn't) |
Thanks for that, Martin. Will have a look. |
Martin, From the CTEK website for the MXS7.0 " It also has a power supply mode which allows the battery to be disconnected from the vehicle without losing important configurations. " Would that cover the requirement? John
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1852 ![]() ![]() |
The 7 will be fine, providing your battery is fully charged, and in good condition to begin with |
Thanks for the replies. I have ordered an MXS7.0 as I needed an up to date charger anyway John
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
I have the ctek 7 charger and an IID tool. Why does it take 70 mins ? Admittedly I have Navcoder and it takes less than 10 seconds to select the option and send to unit.
It takes 70 minutes to re-write the firmware to the Nav screen |
So it's a firmware upgrade rather than just a setting change ?
There is a CCF edit, which takes around 30 seconds, then 2 large firmware updates, at around 35 minutes each |
